09-28-2014, 12:42 PM | #1 |
Drives: 2010 Camaro 2ss/Rs Transformers Join Date: Aug 2014
Best lowering springs for 2010 Camaro ss
Does anyone know what is a good lowering size springs? I have 20 inch rims with the oem ground effects package. I want it be enough to get rid of some wheel gap but still not be scrapping everything, and have the ride be smooth like stock and not bumpy and rough.
YouTube:Krisprz garage
Insta:kris__perez & krisprz_garage LS3 conversion Vararam intake(tune model) Kooks LT headers & cats delete Corsa ZL1 3" exhaust RedBarn Racing Tune CMS Stage 3 Cam AFR CNC ported heads MSD Spark plug wires LNC-2000 Launch controller NGK TR6 Spark Plugs 1le strut tower brace-TPIS spacers Nick Williams 102mm throttle body Fast lsxr 102 intake manifold Slp 25% UDP Katech Tensioner Pulley Circle D 3600-3700 multi disk Stall GM 3.91 gears DDS carbon fiber driveshaft ZL1 fuel pump & injectors Flex fuel sensor(91/E85) https://wheelwell.com/kris-perez |
09-28-2014, 12:47 PM | #2 |
Drives: ‘16 1SS & ‘19 1LT Join Date: Aug 2012
Ask the mods to move your post here:
http://www.camaro5.com/forums/forumdisplay.php?f=93 You should get plenty of responses here.. |
