01-23-2018, 10:51 PM | #15 |
Drives: X-15 Velocipede Join Date: Mar 2008
Sensor resistance decreases as pressure, temperature, or speed is increased and vice versa. As the sensor resistance changes with conditions it provides the PCM with an input voltage signal. If this input voltage signal is not received by the PCM, the circuit is considered open and a P06A3 will be stored.
If the P06A3 is stored alone, suspect that a PCM programming error has occurred. Obviously, you will need to diagnose and repair any other sensor codes prior to diagnosing and repairing the P06A3 - but keep the open "D" circuit in mind. Read more at: https://www.obd-codes.com/p06a3
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer STANDARD DISCLAIMER camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever, whether express, implied, or statutory, including, but not limited to, any warranty of merchantability or fitness for a particular purpose or any warranty that the contents of the information will be error-free. |
01-24-2018, 07:26 AM | #16 |
From what I read, you can also get this code if the input signal to the ECM is out of expected range. It basically treats it like it's open. That's why I think the mods are throwing things out of whack with the ECM's expectations.
01-24-2018, 10:08 AM | #17 |
Drives: 17' 1SS A8 Join Date: Jan 2017
I've had and have been tuned with the same mods for the past 6 months and this is happening to me now for some reason.
2017 1ss e85 /Rotofab/ Ported IM/TB Texas Speed 1 7/8th long tube headers with off road connection
01-24-2018, 11:08 AM | #18 | |
02-11-2018, 11:05 AM | #19 |
Just an update guys I haven’t found fix to this yet. I have to pull over on the freeway every time I do a long pull because I still get the engine reduced power and turn my car on and off. This is so annoying ! I threw my old tune on my car did a few pulls and it went into limp mode again .
02-11-2018, 11:06 AM | #20 |
The code is by itself as well with no other codes
02-11-2018, 05:02 PM | #21 |
What we have here is a failed component.
The circuit is open long enough to set the P06A3, but not long enough to set a trouble code for the offending circuit. Could be a bad sensor Bad wire to sensor from PCM Bad PCM Some research shows Throttle Position Sensors causing this often. They go open long enough to set the P06A3, and cause limp mode (reduced power) Higher underhood temps when doing "runs" increases electrical restistance, and creates the needed parameters to intermittently open-circuit a faulty component. 2 choices - Go to dealer Put a TPS sensor in yourself and see what happens. Check connection and for corrosion at TPS.
02-11-2018, 05:07 PM | #22 | |
Thanks for the write up brother I’ll try to diagnose the TPS. Will the dealer tell me my problem without voiding warrenty? Sent from my iPhone using Tapatalk
02-11-2018, 05:15 PM | #23 | |
Depends on the dealer though. e85 /Rotofab/ Ported IM/TB Texas Speed 1 7/8th long tube headers with off road connection TPS comes with throttle body: BODY ASM-THROT - GM (12620263) SHOP FOR RELATED PARTS IN THROTTLE BODY List Price: $220.00 You Save: $93.50 (43% off) Sale Price: $126.50 https://www.gmpartscenter.net/oem-pa...hrot-12620263/
02-12-2018, 12:52 AM | #24 |
Drives: 2017 M6 NFG Join Date: Jul 2016
good luck figuring out the issue, I know first hand about silly annoying issues but not your specific issue.
02-17-2018, 10:55 AM | #25 | |
So I put in a new throttle body with a new tps and the same problems keep happening :/ so far I’ve diagnosed my tune and throttle body . Sent from my iPhone using Tapatalk
02-17-2018, 11:54 AM | #26 |
Drives: Order List for ZL1 Join Date: Jul 2017
Just a thought, Valet mode?
DRGNZ
02-17-2018, 01:49 PM | #27 | |
If you follow the flow chart, next is to use a dvom to check the circuit, but we have to guess which circuit with no specific code for individual circuit id. So, maybe throw a new pcm in? Or - Take it to the dealer - $$ I know, but they have experience with this issue and can plug new parts in temporarily to aid diagnosis. At a large dealer, the techs talk with each other for difficult cases, and many times someone will say - I had that, took two days to find out that .... Problem solved. To follow up - No trouble codes except blanket open circuit code? Confirmed factory tune has been restored? b
02-17-2018, 04:10 PM | #28 | |
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6 Join Date: Sep 2013
Wierd that it would happen on an A8, though... (just realized you've got an auto). Still, the message sounds similar. --Cal |
