Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
View Poll Results: Which pistons for boosted engine?
Diamond -20cc, 9.25-1 comp. ratio 6 75.00%
Wisco -32cc, 8.5-1 comp. ratio 2 25.00%
Voters: 8. You may not vote on this poll
Old 08-31-2021, 07:22 PM   #1
Vicster
1000hp is NEVER Enough!
Vicster's Avatar
Drives: 13' ZL1
Arrow Need Help, Comp. Ratio for Boosted 427ci
I need to decide between, Diamond 2k -20cc pistons, which will give me 9.25-1 comp ratio. Or Wiseco -32cc pistons, which will give me 8.50-1 comp. ratio with a 0.070" head gasket. I think that I can get 18psi from a Kong 2650 over driven to it's max rpm, because of the cam and heads I have. The higher comp. will have better low rpm throttle response and the lower comp. will allow 3 more psi without pulling as much spark in the tune.
I have the diamond pistons already, will swap them out if a lower comp. ratio if it is really needed. Block is at shop so I have about a week to decide.
I am hoping that others with experience will chime in.
Vicster is offline   Reply With Quote
Old 09-02-2021, 09:09 AM   #2
Robmnrd
Drives: 2013 ZL1
Oof... Admittedly I don't have experience with a build of this capacity, but I think a couple pertinent questions to ask would be what fuel you plan on using and if this beast is track-only, drive to/from track, weekend street beast, frequent driver, or near-DD?
Robmnrd is offline   Reply With Quote
Old 09-03-2021, 02:20 PM   #3
Vicster
Vicster's Avatar
Drives: 13' ZL1
Fuel
Hello,
Fuel is 93 octane with boostane to bring it up to 104 octane, unable to find E85 in my area (have used the web sites and drove around looking). I want to break 200mph in the standing mile and it is a weekend street beast that will see some track time.
After some thought I am thinking that the 9.25-1 comp ratio would suite me better as I really like snapping people's heads back when I leave the line (so to speak). How often do you really see 7500 rpm on the street...
I guess I could compromise and get the Wiseco pistons but bump it up to 434ci at 8.75-1 to 9.0-1 comp ratio.
Thanks for replying
Old 09-03-2021, 09:24 PM   #4
DrkPhx
DrkPhx's Avatar
Drives: 2013 Triple Black ZL1 / 2006 TB SS
If I was building that motor I go to 10.1-1. Better efficiency so you can run lower boost and less timing for a safe reliable set up, but that's me. You need the actual deck height to get the true compression ratio.
DrkPhx is offline   Reply With Quote
Old 09-03-2021, 09:41 PM   #5
Vicster
Vicster's Avatar
Drives: 13' ZL1
Comp.
Hello,
You are correct, The machine shop is aiming for 9.240" deck height as it comes 0.002 to 0.005" taller from Dart for finishing machine work. My rotating assy. comes to 9.240" so deck height should be 0.00" with the Diamond pistons and 0.005" deck height with the Wiseco pistons.
Thanks for replying
Old 09-04-2021, 09:55 AM   #6
Robmnrd
Drives: 2013 ZL1
If you'll be mixing your own it will likely be very consistent and safe to run, so I'd say go ahead with the higher compression ratio as it will better fit your street-enjoyment of the car (You are right, snapping necks is a lot more fun than trying to find a place to run a motor like this up to 7500rpms safely and without catching the attention of the police..).
Looking forward to pics/vids when the time comes, too!
Old 09-11-2021, 10:21 PM   #7
Vicster
Vicster's Avatar
Drives: 13' ZL1
ENDED
Thanks for the replies and the votes! I will stick with the Diamond pistons!
