Old 01-31-2013, 10:47 AM   #1
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
Interesting E15 information
http://washingtonexaminer.com/study-...rticle/2520078
"The additional E15 testing, completed this month, has identified an elevated incidence of fuel pump failures, fuel system component swelling, and impairment of fuel measurement systems in some of the vehicles tested. E15 could cause erratic and misleading fuel gauge readings or cause faulty check engine light illuminations. It also could cause critical components to break and stop fuel flow to the engine. Failure of these components could result in breakdowns that leave consumers stranded on busy roads and highways. Fuel system component problems did not develop in the CRC tests when either E10 or E0 was used. It is difficult to precisely calculate how many vehicles E15 could harm. That depends on how widely it is used and other factors. But, given the kinds of vehicles tested, it is safe to say that millions could be impacted."
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 01-31-2013, 11:29 AM   #2
INTIMIDAT3R
Drives: '11 2SS/RS L99, '12 2LS LFX
Hey, don't knock E15.
The government knows what's best for you and will stop at nothing to make sure you get it.
INTIMIDAT3R is offline   Reply With Quote
Old 01-31-2013, 11:30 AM   #3
awfarley
awfarley's Avatar
Drives: 2011 5.7L Tundra Double-Cab X-SP
awfarley is offline   Reply With Quote
Old 01-31-2013, 05:02 PM   #4
happycamper
happycamper's Avatar
Drives: 2012 2SS/RS M6 AGM
Originally Posted by awfarley View Post
I read that mandantory E15 is being pushed by the corn lobbyists, trying to expand their market for corn.
Right now, E85 in my town is MORE expensive per gallon than regular E10 and E10 has more energy/gallon than E85.
Ashen Gray Metallic w/factory Hurst shifter
Previous: 2011 2LT/RS M6
happycamper is offline   Reply With Quote
Old 01-31-2013, 09:29 PM   #5
LIVEVIL
LIVEVIL's Avatar
Drives: Camaro
So how come E85 and E10 are all fine and dandy, but somehow E15 is the bane of all evil and melts fuel systems?
LIVEVIL is offline   Reply With Quote
Old 01-31-2013, 09:54 PM   #6
Jrichards73
Jrichards73's Avatar
Drives: 2011 2SS/RS Victory Red
uh I wouldn't put E85 in your car, and a flex fuel car would run fine on E15. The cars they are talking about are the other 90% made to run on gas... Ethanol (alcohol) is mildly corrosive to the fuel line o-rings and doesn't keep them supple. You develop leaks damage injectors etc. This is all correctable in the initial assembly of the vehicle. People are broke and buying a new car to just run a different gasoline isn't viable.
Updates: BTR Stage 2 VVT Cam Kit w/Smith Brothers Trunnions, Fluidampr, RX catch can, B&M Trans pan mod, Kooks Black Headers, Borla S-tunes, Eibach Multi-Pro-R2 coilovers and Swaybars, BMR Full Bushing kit with Toe and Trailing arms, RB Rotors w/EBC Pads, GForce 1400 Axles (now on order). AVH-X5800BHS in Scosche GM5201AB.
Jrichards73 is offline   Reply With Quote
Old 02-03-2013, 01:05 PM   #7
Jayrcr3
Jayrcr3's Avatar
This^^^^
The fuel itself isn't the problem. Most cars aren't built to handle the amount of alcohol in E15. At E10 and below levels its diluted enough that it doesn't cause any damage. If the government forces the use of E15 its going to cause problems for cars that weren't built for it.
Old 02-03-2013, 01:15 PM   #8
jd10013
Drives: 2012 camaro
Originally Posted by Jayrcr3 View Post
This^^^^
it's not that they're forcing us to use E15, it's more the amount of ethanol that's mandated to be used. the number of gallons goes up every year, and without an increase in gasoline use the only way to absorb the additional gallons required is to increase the amount of it in every gallon of gas. it wont end there either. as more and more ethanol is required that percentage will necessarily have to go up. E20, E25, and E30 are in our future. and the worst part is, this is mandated in law. that's why gas companies have to do this. and it's not a regulation that can just be undone.
jd10013 is offline   Reply With Quote
Old 02-03-2013, 01:16 PM   #9
jd10013
Drives: 2012 camaro
E85 is only fine and dandy if you have a flex fuel vehicle. otherwise, you will ruin your car.
Old 02-03-2013, 03:37 PM   #10
Russell James
Russell James's Avatar
Drives: '15 SS 1LE, '69 Z28 drag car
Just check your owners manual for what it was designed for. I know my '10 SS was E10, and my '12 says '15. Not going to melt anything if it was designed for it. But don't put E15 in a car that was only engineered for E10.
Russell James is offline   Reply With Quote
Old 02-04-2013, 09:28 AM   #11
LIVEVIL
LIVEVIL's Avatar
Drives: Camaro
So all these Cobras and Evos and Supras and Camaros and Corvettes running E85 in their boosted cars are all flex fuel vehicles from the factory?
Old 02-04-2013, 09:31 AM   #12
jd10013
Drives: 2012 camaro
that or modified to handle E85. look, if you think people are just lieing go put some E85 in your car and see what happens.
Old 02-04-2013, 09:35 AM   #13
LIVEVIL
LIVEVIL's Avatar
Drives: Camaro
In fact I have, been running combination of straight E85 (for racing) and 93 (for daily driving) for a few years now on completely OEM lines and tank. Only things changed in the fuel system were the injectors and fuel pump.
Old 02-04-2013, 09:56 AM   #14
jd10013
Drives: 2012 camaro
of course you have. you race with E85 despite the fact ethanol produces far less power than gas.
now tell me how you blow the doors off everyone too.
