Roto-Fab
Old 02-09-2014, 11:17 PM   #1
JHall651
JHall651's Avatar
Drives: 2012 Camaro 2SS LS3 Ashen Grey
9 PSI w/ 2" Headers???
What would be the BEST / Reliable (not necessarily most cost effective) way to achieve a solid 9 psi with 2" headers using a Maggie 2300? (i.e. Rear OD/Front UD Combo?)
2012 2SS/RS, Magna TVS2300, RX Catch Can, Borla S-Type, Pfadt Stage 4 w/ ZL Spec Sway Bars, ADM Custom Boost/AFR Gauges, Hurst Short Throw, Forgestar F14 Matte Black 20x11 & 20x9.5 Deep Concave all 4, Nitto Invo 315/35 & 275/40, Heritage Grill, Sparks Black Grill SS & Trunk SS, P13W Fog Lights (cool white) w/ DRL Harness, Blacked Out Brake light bezels, Xpel Smoke Light Kit
JHall651 is offline   Reply With Quote
Old 02-09-2014, 11:22 PM   #2
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
Proper pulley choice?
-John S.
grocerygetter is offline   Reply With Quote
Old 02-09-2014, 11:25 PM   #3
JHall651
JHall651's Avatar
Huh? Are you asking me?
Old 02-09-2014, 11:49 PM   #4
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
Rear OD is the way to go. If you want to go past roughly 15 you'll need to go to a front overdrive kit as well.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 02-10-2014, 03:19 PM   #5
JHall651
JHall651's Avatar
15! No I'm trying to find out the best way to only gain like 2 more PSI after installing 2" headers. I want to be at 9 PSI, maybe 10 during a spike but no higher. I really like the cogs but again I don't want to go to higher than 9-10 PSI. So was curious if the 2" header w/ OD Cog will put me at 9 or would I also need to add front UD Pulley. If so what PSI would that combo (2" headers/rear od & front ud) put me at? Thanks for the help guys.
Old 02-10-2014, 03:29 PM   #6
jvoisel
Drives: 2010 2SS/RS M6
I have:
Stock 3.8" front pulley
OD rear cog
XS Power 2" headers
ADM CAI
Made just over 10psi on the dyno and 550rwhp/565rwtq on a conservative tune
2010 2SS/RS
jvoisel is offline   Reply With Quote
Old 02-10-2014, 03:57 PM   #7
JHall651
JHall651's Avatar
Originally Posted by jvoisel View Post
I have:
OD rear cog
XS Power 2" headers
ADM CAI
There we go! Great info. Thanks a lot. What was the temperature like when you dyno'd that setup and were just over 10 PSI? I wonder if putting the front UD Pulley would put it at 9 or would make it too low? I have just always heard anything over 10 PSI and you are pushing the limits on stock internals. That is why I would like to stay at 9 with the very max being 10 during those cold days when it likes to spike up a bit in PSI.
Old 02-10-2014, 04:13 PM   #8
Ron_Robinson1
Ron_Robinson1's Avatar
Drives: A Static line to a pack tray & ZL1
Send a message via AIM to Ron_Robinson1
A lot depends on what your fuel system consist of injectors, fuel pump, and Octane 91/93?
There is a lot of people over 10lbs of boost ls3/L99. I don't think it's the boost number that kills a motor, but cylinder pressure (hp). And if you have supporting fuel mods, and a good tuner 10lbs should be fine.
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4)
SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129
SOLD-2011 SS M6: Blower, Cam, Alky, LTs.
Ron_Robinson1 is offline   Reply With Quote
Old 02-10-2014, 05:16 PM   #9
old motorhead
Drives: Maggie blown LS3 vette
If you don't have belt slip, you'll be well over 10psi with a 3.8 front pulley with overdriven rears. That's assuming stock cam and VERY open exhaust. If you have less with a similar setup, you probably have restrictions before the throttle body.
old motorhead is offline   Reply With Quote
Old 02-10-2014, 05:23 PM   #10
jvoisel
I have stock cam, 2" headers, full 3" exhaust with the only mufflers being two short straight-through mufflers. I see over 10 psi but not too much over it or a normal day (70+deg) On a cold (under 40deg) night I have seen a hair over 11psi, but I have full confidence in my tuner and don't doubt one bit that it'll hold it. Cam/meth/12-13psi coming soon on stock bottom end.
Good tune is key.
2010 2SS/RS
Old 02-10-2014, 07:12 PM   #11
JHall651
JHall651's Avatar
Thanks so much everyone! Loving the input. Roger that on a good tune. I will be going to one of the most well known and best in the industry. I am just trying to do a bit of homework. I always lean towards the conservative side, especially considering for 70% of the year this is my daily driver. Does anyone know what a OD Cog and UD Pulley puts you at (PSI wise) w/ 2" headers and CAI?
Old 02-10-2014, 08:24 PM   #12
jvoisel
If OD cog makes 11 psi (max) and you add a 25% ud pulley, probably around 8.25 max. likely closer to 7-7.5
Have you talked to a tuner? IMO, you will have no issues running OD and stock crank pulley. Otherwise, just drop to a 3.6" up front. Cheaper to do that anyways
2010 2SS/RS
Old 02-10-2014, 08:53 PM   #13
JHall651
JHall651's Avatar
Thanks for the advice. I am seeing a common denominator in that most people (including my local tuner) are pretty confident that the OD Cog and stock pulley will be safe at just above 10 PSI. As far as going with the 3.6 up front I kind of have my heart set on the OD Cog, for the performance of course, but also the sound.
Old 02-10-2014, 08:56 PM   #14
jvoisel
Sounds is amazing haha.
Goodluck with the car Bud! Let us know what it makes.
2010 2SS/RS
