Old 12-02-2016, 11:24 AM   #15
Heavymetal454
Drives: '69 RS Pro Street
Awesome. Once again we went from an intelligent discussion to gender bias in less than a few minutes.
The truth is he was driving uphill pulling a trailer and he had the e brake on.
173 is not top speed as evidenced by the Nurburgring video. Drive hard, live fast!
Heavymetal454 is offline   Reply With Quote
Old 12-02-2016, 11:35 AM   #16
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
I wonder what he was pulling in the trailer?
Old 12-02-2016, 11:38 AM   #17
newb
newb's Avatar
Drives: 2013 1LE
The 2018 Mustang GT500...
It's a Dingledarm. It's there to dampen side fumbling. If your marzelvanes fumble too much they can cause total protonic reversal. It gets ugly from there. This is really the biggest problem with the new Camaro. That and the tri-pronged blivot.
Delivered 21 Jan 2013
newb is offline   Reply With Quote
Old 12-02-2016, 11:39 AM   #18
Michigan1LTRS
Blessed ❤️
Yeah, probably broke down in the test mule stage.
Old 12-02-2016, 11:51 AM   #19
JulesWinnfield
Drives: M
OK, I apologize for being rude. I did not listen...
173 is unimpressive. Modern diesel germans can go faster. If this is the only manual u can get,I'd go with an auto. Even though before this video I wanted a stick.
JulesWinnfield is offline   Reply With Quote
Old 12-02-2016, 01:22 PM   #20
Heavymetal454
I totally agree. Unimpressive considering you have contributed so much over the last 7 posts you have entered on this forum. Perhaps you could go into journalism with your vast knowledge of automobiles. No doubt you have built many race engines as well and could teach those silly engineers a thing or two with your plethora of knowledge.
The greatest strength is restraint. Thank you for your unimpressive commentary. Carry on!
Old 12-02-2016, 03:05 PM   #21
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 12-02-2016, 03:29 PM   #22
KLR ZL1
H-Town Camaro Club Member
KLR ZL1's Avatar
Drives: 17 Hyper Blue Metallic KLR-ZL1
Originally Posted by snackbar64 View Post
At the very top of 5th gear at 173 mph he said the car would not go any faster and was at the rev limiter. He briefly went to 6th gear and the rpms dropped dramatically. That is what I saw. The car reaches its top speed in 5th gear.
Well actually he let's off then shifts to 6th gear and let's off the gas in that gear and continued to slow down. It also would make a difference if he had a head wind. Maybe he should have ran in both directions to be more accurate. Oh and remember he is trying to sell his upgrades and I guarantee that will break 200 even if he has to cheat with nitrous like he did with the vette.
KLR ZL1 is offline   Reply With Quote
Old 12-02-2016, 03:37 PM   #23
Memphis
Drives: Bucket
6th is like .5 so I am not surprised if it doesn't have enough power to overcome that but look at how hard it was pulling still in 5th. Going to 6th would put it at <4000rpm at that mph.
Memphis is offline   Reply With Quote
Old 12-02-2016, 03:43 PM   #24
Stoner
Drives: 2017 ZL1 HBM, M6
Are u talking about the hennessey video? 173 is not a top speed. He only took to 5th gear. There is one more gear(6) that he did not use.
Jeez, sometimes I feel like this is a Toyota prius forum for women.
Stoner is offline   Reply With Quote
Old 12-02-2016, 03:44 PM   #25
Jeffro19
Jeffro19's Avatar
Looks like he hit 6700rpm in 5th. I'm pretty sure he hit the rev limiter and that's why it cut out at 173. He shifted into 6th gear after the rev limiter hit but never tried to accelerate So we don't really know if it would still be pulling in 6th. My guess it is would still pull a bit but the acceleration would drop off dramatically and also would depend if he was going into the wind or if you are going up a slight incline or not.
Old 12-02-2016, 04:14 PM   #26
17CamaroZL1
He definitely hit the Rev limiter and he actually did try to accelerate in 6th. You can barely hear it, but it sounds like the engine was bogging and you can clearly see the boost max out again right before he lifted because he knew it wouldn't pull.
12/26/2016 Ordered!
2/8/2017 Built!!
Old 12-02-2016, 04:28 PM   #27
mcsoul
Drives: Want a gen 6
I'm pretty sure the 202 mph he did in his m6 SS HPE700 was in 6th gear too. Is 6th different .5 (ZL1) vs .74 (SS) or something? Both use a .373 rear.
mcsoul is offline   Reply With Quote
Old 12-02-2016, 04:45 PM   #28
17CamaroZL1
If that's the 6th gear ratios of each, that is a huge difference! Much easier to pull with the .74. I would think .74 should be close to 5th in the ZL1.
12/26/2016 Ordered!
2/8/2017 Built!!
