02-27-2023, 04:14 PM | #1 |
Drives: 2010 Camaro SS/RS Twin Turbo Join Date: Dec 2022
Going for 8 sec. 1/4 mile
Raced a 2000hp Lambo the other night.He gave me a head start!😂I was testing out my new Bosch 210 injectors and E85 tune.Lifted right before the 1/8th and ran 5.75 @ 122mph.Should be good for high 8's in the 1/4 mile. https://youtu.be/VGmqxJP92Mo
2010 Camaro SS 416 Twin Turbo,4L80E trans,ZL1 rear.1065 rwhp.9.03@154 1/4 mile so far.
02-28-2023, 06:58 PM | #2 |
Drives: 2014 Camaro SS Join Date: Feb 2022
That's fkn moving man! Full weight?
02-28-2023, 07:43 PM | #3 | |
Drives: 2010 CAMARO RS/SS Join Date: Jul 2021
03-01-2023, 03:36 PM | #4 |
I removed the pass. and rear seat, still weighs 4140 lbs. with me in it.
03-01-2023, 03:37 PM | #5 |
03-03-2023, 11:11 AM | #6 |
Drives: 2015 Camaro SS commemorative Join Date: May 2015
do you leave in first gear with the 4l80? And which ZL1 gear ratio are you running?
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
03-04-2023, 04:31 PM | #7 |
I leave in first gear with 5 to 6 psi boost.ZL1 rear is 3.23.
07-06-2023, 05:18 PM | #8 |
Drives: zl1 blk Join Date: Nov 2017
was that run on 20inch tires ????
07-07-2023, 12:32 PM | #9 |
Very nice run bro!!
07-07-2023, 12:34 PM | #10 |
Looking at his vid, those look like 20 inch Z28 replica wheels.. Unless they are OEM, then they would be 19's.
07-09-2023, 09:34 AM | #11 |
I have 17in on the rear and 18in on the front.
07-09-2023, 09:35 AM | #12 |
12-23-2023, 05:07 PM | #13 |
Drove down to the Christmas tree race for test and tune.Lined up against an 1150 rwhp supercharged truck.Just missed an 8 second pass but still got the win! 9.03 @ 154 to a 9.6 @ 145 mph.https://youtu.be/Pd2mYr1wruA?si=niDp3MxtOwicI9fY
12-23-2023, 05:36 PM | #14 | |
