07-04-2014, 11:53 AM | #15 |
Drives: '11 SW 2SS/RS LS3 Vert Join Date: Jul 2013
I either leave the car outside for a bit to cool off or if I have to get it inside right away (raining, etc) I'll open the garage door full or half way at least for a while.
07-04-2014, 12:06 PM | #16 |
750HP of Twisted Reaper!
Drives: Blk 2SS/Blk Carb Fibr NS-1 stripes Join Date: Oct 2010
Mine is extra hot with LT's.
Fear the LMR Twisted Reaper Brotherhood!
07-04-2014, 12:18 PM | #17 |
Anabolic Connoisseur
Drives: Sold - Blown Camaro 2SS/RS LS3 Join Date: Sep 2010
07-04-2014, 12:52 PM | #18 |
Buick 455 Fan
Drives: 1970 Buick, 2012 1SS LS3 Join Date: Jun 2010
That only proves coolant temperature.
07-04-2014, 12:57 PM | #19 |
Drives: 2013 1SS Blue Ray metallic Join Date: May 2013
Try hood vent like this.
07-04-2014, 01:00 PM | #20 |
Drives: 2014 CTS-V- totalled/ 45TH ss- SOLD Join Date: May 2013
This brings up a debate I am having currently. My LTS make it hot under the hood with the cam, to the point where after driving a while, my starter gets heat soaked and doesn't want to restart easily. All gauges read accurately. Occasional misfire code blinks from the plug wires. Trying to figure out ways to vent it and cool it. Cats being deleted helped a little, but not a problem solve. Any suggestions?
2014 CTS-V... with some go-fast bits coming
07-04-2014, 01:17 PM | #21 |
And the above extractor wont work because 45th decal on the hood. unless I get both painted on, with the extractor.
07-04-2014, 04:06 PM | #22 |
It surely does. But it's totally normal.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
07-04-2014, 07:30 PM | #23 |
100% Sport Møde
Drives: '17 Civic SI + '04 SVT Lightning Join Date: Apr 2012
Well I noticed today that my coolant temp can sometimes stay at 189/190 degrees and then sometimes is goes up to 199. It was at 189 after 40 minutes of driving but it was cooler today. My V6 shot up to 199 degrees and stayed there. Is it normal for the V8 to run as cool as 189 or do I need a thermostat?
07-04-2014, 07:44 PM | #24 |
There are normal variations for the coolant depending if your cooling fan is on, ac is on or off, and load on the engine. Mine varies from 189-220, and it's 100% normal. It won't go over 202 with A/c on, it will go to 220 without. If you ever hit 230-250, then worry.
07-04-2014, 10:24 PM | #25 |
Drives: 2017 Camaro SS (2SS, M6) Join Date: May 2014
There's a lot of aluminum and metal in the engine compartment getting heated up so it's going to give off some heat for awhile after you shut her down. No worries, just think of it as a 6.2l space heater.
07-04-2014, 10:33 PM | #26 | |
ace5.org
Stock...For Now.
07-04-2014, 10:36 PM | #27 |
Drives: 2014 2SS L99 Join Date: Mar 2014
07-04-2014, 11:05 PM | #28 | |
Drives: 20 X3M CP & 19 ZL1 1LE A10 Join Date: Jun 2013
🔺22 RS E TRON GT
🔺21 Model S Plaid |
