05-17-2021, 04:46 PM | #29 | |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
https://www.camaro6.com/forums/showthread.php?t=592211 (edit: yes, the pics are of the v6 t-stat...but it's the same issue in the v8 t-stat) this is the same kind of surface film anyone familiar with dexcool would recognize. Nothing really new there as dexcool has been doing this since the beginning. The only difference is old dexcool would eat gaskets too. To clean it, i'm not sure what you would want to use to dissolve it without using an abrassive action of some kind. I could try some things, i still have mine out and uncleaned. However, if it was very easy to get off the surface of metal, there would be some known remedies for getting it out of radiators and such in threads from previous horror stories of older formulations of dexcool really caking on the entire coolant system of cars. I dont know of any flushes that remove it from the surface. but since this is just a t-stat, some other solvent options may be available that do work (like dipping in gasoline etc) |
02-24-2024, 02:46 PM | #30 |
Drives: 2016 2LT Join Date: Jun 2022
Ready for a brain scratcher? Here's my issue.
Minding my own business driving to or from work and my coolant gauge drops to min. Fan spoils up.. Reset error codes.. Its goes back to normal op.. But here's mind boggler... It happens within a 1/4 mile of the same spot everyday.. at first i thought it might be some kind of RF interference.. but more people would have the same issue. At this point idk wtf is going on.. I've changed the sensor out.. wires looked fine. |
02-24-2024, 03:45 PM | #31 | |
Just a conjecture, but since you replaced the temp sensor, let's assume it was not the cause, but it could also be the thermostat opening too early, triggering a code that then causes the failsafe logic to kick the fan into high gear, which then quickly drives the coolant temp down and the gauge backwards. I'm not a mechanic, so what I would do is replace the thermostat, clear the code(s) and hope for the best
02-24-2024, 04:03 PM | #32 |
That happened to me. New thermostat resolved the issue.
02-24-2024, 04:09 PM | #33 | |
My wild guess is thermostat is sticking. When coolant gets up to temp it pops open too far, sticks again, then gauge reads dropped temp. ECM sees this as a fault, and sets the fans to high, which I believe is the "failsafe" mode. Happens at the same place because that's where you hit that coolant temp on your route. You might be able to see signs of this on the digital gauge if I am right. It should climb pretty normally, then drop quickly before it bottoms out. |
02-25-2024, 04:23 AM | #34 |
Drives: Chevrolet Camaro 2LT RS V6 3.6L Join Date: Jan 2024
Had the same problem on my 2017 RS V6. There was no reading on digital dash gague and zero reading on the analog type gague on dash. Problem was the thermostat which aftermarket dealer warranty covered. Mostly covered. I got $600 off an $800 job (with my $100 decuctible it cost me only $100 extra).
These problems are usually the sensor or the thermostat. Sensor replacement is cheap and you can do without taking everything off. If that doesn't fix it, then its a faulty thermostat. They stick sometimes or just fail somehow but either way the thermostat replacement is the second thing to try. I know the thermostat is not digital so it can't fail due to RF interference since its mechanical in nature. Like someone said, if its same spot it's distance driven not location. If you sense a temp reading then it goes bad, its because thermostat failed to open causing a logic error in the computer because thermostat and sensor don't "match" giving you a visible error to the driver letting you know something is wrong. The sensor not only senses temp but also if the thermostat is open or closed at appropriate temps. Have a mechanic read the code but if you sense a temp on start up, its not the sensor at fault.
2017 Camaro RS V6 3.6L
02-26-2024, 12:59 PM | #35 |
Drives: '16 2SS M6 Join Date: Aug 2019
When the thermostat sticks open, even just a little bit, it takes the engine longer to heat up. This triggers the code and the computer drops the gauge to zero and turns the fan on high. This has been discussed many times on here.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer |
