dave@hennessey
Old 07-02-2017, 05:04 PM   #1
G701LE
G701LE's Avatar
Drives: 2010 2SS/RS L99 IBM silver stipes
DON'T THINK FOR ONE SECOND.....
DON'T THINK FOR ONE SECOND YOU ARE JUST GOING TO BAKE YOUR HEADLIGHTS AND BREAK THEM OPEN!!!!!!!!! I have baked mine about 10 times now. I have about 3 holes in me, about 10 nice scrapes. AND THEY ARE STILL NOT OPEN!!!!!!! I have pried and carved around the edge with a knife and a screwdriver. Can anybody say DYNAMITE
2010 Imperial Blue w/ Silver stripes 2SS/RS L99
Mods = Not enough....
G701LE is offline   Reply With Quote
Old 07-02-2017, 05:07 PM   #2
G701LE
G701LE's Avatar
Cracks on the lens now. Don't believe all these videos with BRAND NEW lights. Not as easy as it looks......
Old 07-02-2017, 05:12 PM   #3
G701LE
G701LE's Avatar
Just a few
Old 07-02-2017, 05:15 PM   #4
myold88
myold88's Avatar
Drives: SUMMIT WHITE 2SS/RS CAMARO
Did I miss something? What are you trying to do?
myold88 is offline   Reply With Quote
Old 07-02-2017, 05:24 PM   #5
G701LE
G701LE's Avatar
I am trying to take apart my headlights and put halos in
Old 07-02-2017, 06:42 PM   #6
TheFlyingBananaSS
Evil Genius of Chevrolet
TheFlyingBananaSS's Avatar
Drives: 2017 Z06, 2019 XTS, 2013 SS
Patience. Slow down. Get them good and hot. They should be hot enough that you need leather gloves to handle them. That's when they become most workable.
GPI SS2 VVT cam, ECS Novi 1500 supercharger, Corsa Extreme, Detroit Speed and BMR suspension, Circle D triple disc, Melling oil pump, LS2 chain tensioner, ATI 10% UD, DSX E85 kit, High Energy coils, BTR springs, LS2 Lifter trays, Titanium retainers, hardened push rods, FIC 1000 injectors, ZL1 pump, Mighty Mouse catch can, AEM gauges, Tial BOV, Richmond 3.91 gears, Custom gauge bezels, Speed Engineering headers, Stainless Works HF cats, DSX Aux pump, 710rwhp on E85.
TheFlyingBananaSS is offline   Reply With Quote
Old 07-02-2017, 06:57 PM   #7
CamaroFred
CamaroFred's Avatar
Drives: Miss Con Ception
Your sig says you have an RS. Don't they already have halos?
2011 1SS/RS LS3 CGM
CamaroFred is offline   Reply With Quote
Old 07-02-2017, 08:01 PM   #8
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
I had no problems baking headlights on any of the cars I've done it to.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 07-02-2017, 08:09 PM   #9
Cyber10
Cyber10's Avatar
Drives: 2010 Camaro 2SS/RS
Not only did I bake mine to put in different color halos, I baked one again after the lens shattered in an accident and transferred a different lens onto it. So I cracked open 3 headlights 4 times, one of which was one I sealed(and sealed it generously at that) and had no issues with any of them.
491 hp/438 tq
LS3 Conversion | Comp Cam Custom Grind | Mast Heads | Comp Cam Push Rods | LS7 Timing Chain | 180 Thermostat | Ported Intake | Ported TB | SLP UDP | K & N CAI | Custom 3800 Stall Converter | Aluminum 1 Piece Driveshaft | Kooks 1 7/8" LTH | High Flow Cats | ARH 3" Exhaust | ARH Mufflers | Eibach Lowering Springs | BMR Floor Brace Subframe Connectors with Tunnel Brace | BMR Moly Lower Rear Control Arms | Oracle LED Halo Kit
Cyber10 is offline   Reply With Quote
Old 07-02-2017, 09:29 PM   #10
G701LE
G701LE's Avatar
Ok. At what temps and how long did you guys bake them? I have seen anywhere from 200* for 10 minutes to 220* for 12 minutes. I tried both methods and they are no where near coming off. I don't want to ruin them, so a little more info would be appreciated
If I ever do get them open.... Do I want to use the stock diffuser?
Old 07-02-2017, 09:32 PM   #11
shibbs
Captain Gingerbeard
shibbs's Avatar
I baked mine at 250 for 10-15 minutes. Took all the bulbs out, put it on a towel on a cookie sheet. Came right apart.
Old 07-02-2017, 09:35 PM   #12
G701LE
G701LE's Avatar
Thanks man! Do I want to use the stock diffuser?
Old 07-02-2017, 10:15 PM   #13
G701LE
G701LE's Avatar
250* for 15 minutes......done. Still not soft enough.......
Back in they go. I don't give a fu2k at this point if I melt them. They are coming apart like it or not!!!
Old 07-02-2017, 10:30 PM   #14
G701LE
G701LE's Avatar
I have literally tore my lights up and they aren't coming apart still. 25-30 minutes now at 250*. HELP!!!!!!!!!!!!!!!!!
