01-25-2017, 12:14 PM | #1 |
Drives: 2015 camaro 2lt Join Date: Dec 2016
drive train loss hp
is there anyway or mods that reduce the loss of hp to whp like a carbon fiber driveshaft but i belive thats just weight.
Cosmetic mods: SS hood with painted vent, SS bumper, acs 1le front lip black, big worm gfx tinted all lights, solar wing v2, Camaro seat belt pads and oracle color shift halos and fog light halos and rear colorshift bow tie, carbon creations carbon fiber stingray z spoiler
Wheels: lexani r-3 bg finish 19x8.5 Performance: cold air inductions intake, mrt v1, jacfab ported intake manifold, intake manifold spacer, overkill tuned on E85. |
01-25-2017, 12:46 PM | #2 |
Ben Rakers
Rotational weight is where you loose horsepower. a lighter driveshaft will actually give you better numbers because the engine isn't working as hard to turn a heavy driveshaft. At least that's how it was explained to me. The more rotational mass you can loose the quicker you will be. Cut weigh in the rotating assembly before UN-sprung weight. But on a V6 I wouldn't worry too much about it, no offense but unless you plan on making huge power numbers your wasting money.
2011 Camaro 2SS/RS K&N Blackhawk Cold air intake, Hawk Performance Ceramic pads, BAER drilled and slotted rotors, Side louver black faded inserts, Hurst Short Throw Shifter, BMR Trailing Arms, Elite Engineering Catch Can, MSD Spark Plug Wires, Texas Speed 1 7/8in Headers and cat back, High Flow Cats, 3 inch X-Pipe, Speed Dawg shift knob, Tuned by Nickey. And oh, its My first car.
https://www.youtube.com/channel/UC_L...5jF6EQEoKDNQ2g |
01-25-2017, 12:55 PM | #3 |
Drives: Miss Con Ception Join Date: Aug 2016
Lighter wheels.
2011 1SS/RS LS3 CGM
01-25-2017, 01:06 PM | #4 |
I'm planing on making 600whp
01-25-2017, 01:34 PM | #5 |
Drives: 2013 Camaro 2SS RDP Tuned L99 Join Date: Apr 2013
01-25-2017, 01:50 PM | #6 |
Drives: 2018 1SS M6 Join Date: Nov 2014
01-25-2017, 02:01 PM | #7 |
Drives: 2013 2SS/RS Join Date: Nov 2015
Plan on spending almost as much as your parents paid for the car.
01-25-2017, 02:23 PM | #8 |
Drives: LSX FTW Join Date: Feb 2016
Not worth it imo. save up and get yourself an SS or ZL1 that's worth putting money into. not to be a douche but even turbo v6's are a joke not only engine work, but suspension, drivetrain work as well. you'll be into it way more than the car is worth. but to each its own
#Gapped
01-25-2017, 02:28 PM | #9 |
Started#gottalovethatblue
As stated above, rotational weight is the best way to eliminate some loss of horsepower to the wheels. Lighter harmonic balancer, lighter drive shaft(s), and lighter wheels/tires are good places to start. Then of course manual transmissions have less powertrain loss than automatics, again less to turn. If you're looking for the quickest, best bang for the buck rotational weight reduction go with wheels and a new balancer. You're thinking right with the drive shaft, but that will cost a lot of money and yield less power than reducing the other weight areas.
01-25-2017, 02:48 PM | #10 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
01-25-2017, 03:40 PM | #11 | |
Drives: '13 2LT/RS Twin Turbo Join Date: Aug 2012
3.6L Twin Turbo V6 Garrett GT28 turbos -- Jacfab forged connecting rods -- Diamond forged pistons(10.5:1) -- Alky Control Methonal Injection -- CircleD 2E triple disc torque converter -- BMR suspension 10.75 @ 131mph |
01-25-2017, 03:45 PM | #12 | |
376 cubic inches of fun
01-25-2017, 03:54 PM | #13 | |
Drives: 15 Z28, 01 Corvette, 96 Corvette Join Date: Dec 2016
Lowing rotational mass will help a very small amount with the numbers. It helps with the feel. Lighter rotational mass means the car revs up faster and takes of faster. Lightend: Flywheel, Clutch, wheels, brakes, crankshaft, pistons and such. 600 rwhp is pretty easy in an LS with a vortech super charger, headers, fuel pump and fuel injectors. You can get to 700 with a cam on top of all that. I have a dyno sheet to prove it for anyone who wants to argue. As long as 598 rwhp counts as 600. |
01-25-2017, 03:55 PM | #14 |
wait... he has at V6.... and wants that power.... Dude save your money and buy a V8.
Forget everything I said. V6 are a total waste of money if you want that power. Will cost $15k or more to get to 600 rwhp on a V6 and the motor will be at its limit. For half that you can by a V8 car. |
