07-20-2016, 02:30 PM | #29 | |
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
07-20-2016, 05:42 PM | #30 |
Drives: 2016 Camaro 1LT Join Date: Apr 2016
They will boil over before they will overcharge that much. I was a locomotive electrician for 39 years. I dealt with 64V systems. So Glen can be more precise on what to look for on 12V systems. But I completely agree with him when he says if you check the battery while it is running you are checking the charging system and not the battery. Whence my earlier comment about looking at what the battery is doing DURING the starting process. On locomotives, we would put the meter across the battery switch, if the voltage went below 46 volts we knew the batteries were bad. I have seen batteries read 64V and not be good. It can be that they need a charge but it can also be a bad cell.
Life after retirement |
07-21-2016, 12:12 AM | #31 | |
Drives: 1LS MT Join Date: Feb 2014
Per the owner manual the car has an Absorbed Glass Mat (AGM) 12 volt battery. When using a 12 volt battery charger on the 12 volt AGM battery, some chargers have an AGM battery setting on the charger. If available, use the AGM setting on the charger, to limit charge voltage to 14.8 volts. In other words the chart shows 12.7=100%. My battery shows 13.76 and I have charged batteries up to 14.8. If my battery would show 12.7 like in your chart it would be a dead battery. 1 volt difference on your chart shows a dead battery, 12.7-11.7, 1 volt difference on my battery and I would not be able to start the car. |
03-29-2017, 01:23 PM | #32 |
Drives: 2016 SS Mosaic Black Join Date: Jul 2012
This actually just freaked me out. I've never seen a car that rests at 12v while running. Has always been. 12.6 off and 14.4 on.
03-29-2017, 01:49 PM | #33 | |
Retired from Car mfrs....
No battery, no matter what type, that's ever used in a car, is dead at 12.7. Yes, SLIGHTLY diff, but certainly not avresting voltage at 13.76: See the third paragraph here: https://www.solar-electric.com/deep-...at%20Batteries
03-29-2017, 02:06 PM | #34 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
Keeping this simple from an electronics/biomed technician who has installed and repaired more than a few car stereo and vehicle security systems going back to the 90s.......
Ever since the 1950s when the electrical standard for all North American production cars changed from 6v with a generator to 12v with an alternator, its remained essentially the same: a fully charged battery with the engine/charging system off will read 12-13 volts, and NO MORE. When the engine/charging system is on it will read 12-14.4 volts. If you measure your electrical system in those states and your readings fall within those parameters in those states, your battery and charging system are operating properly. This applies to every car, truck, van, SUV you can name that was ever produced for the North American market since 1958. |
07-29-2017, 05:59 PM | #35 |
Drives: 2017 1LT RS V6 A8, 2020 Fusion Join Date: Jun 2017
Not What I learned 46 Years Ago, Old School
I was taught that charging voltage should be between 13.8v-14.2v.
The static charge on my battery showed 12.8v I would assume that anything less than that while driving would indicate a DISCHARGE condition. For the past several days, I have had the voltage displayed on my 1LT. Sometimes it reads 13.8v. Sometimes it reads 12.1v. A reading of 12.1v while driving is very disconcerting. Even a "float charge" is 13.5v from what I remember. So is our voltage monitor showing that the alternator is only charging 12.1v back into the battery? Wouldn't an AMP gauge be more useful? And really, what is the point of that information as opposed the what is actually going on AT the battery, ya know, like it's been all along? The owners manual does not fully explain this "smart charge" or "EPM" as they apparently call it. Last edited by LtColumbo; 07-29-2017 at 06:47 PM. |
07-29-2017, 06:23 PM | #36 | |
07-29-2017, 06:45 PM | #37 |
I just went to my car and put it in "service" mode. The voltage read 12.5v without the engine running. So if the voltage reading is "charging" voltage, and the engine was OFF, it should have read 0.0v?
But you're saying that somehow the gauge knows the difference between whether the engine is running or OFF? |
07-29-2017, 06:46 PM | #38 |
Yup .....service mode actuates the gauges to read, so you get the resting voltage. Start the car, which starts the batt to read what's coming in from the alternator, so it reads >13.....
This is ford but GM is same: http://www.valeoservice.com/data/mas...E6E8714173.pdf |
07-30-2017, 11:21 AM | #39 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
I guess what we need is an update to the firmware so instead of a voltage it just says "good, low, bad".
07-30-2017, 11:22 AM | #40 | |
Sent from my SM-G950U using Tapatalk
07-30-2017, 11:23 AM | #41 | |
Actually prob just "charging/no charging" would prob do.....LOL |
07-30-2017, 11:53 AM | #42 |
OR maybe and alternator icon OR amp gauge instead of a battery icon!
