04-03-2016, 09:57 PM | #15 |
I used to be Dragoneye...
To all that's been said. It's normal.
And Quicksilver...your car is gorgeous!!! |
07-19-2016, 06:00 PM | #16 |
Drives: 2022 CT4-V Blackwing Join Date: Sep 2013
Anyone have a voltage reading of their battery with the engine off. I am getting 12.32v. It starts, but I feel like the starter is initially slow to turn over. The charging meeting on the display does the typical stuff when driving. It will show somewhere around 14v for a bit and then drop down to 12.5 or so? Are these starters slow to turn over these engines? Wondering if 12.32v is ok, I would think it should be at 12.5 or higher?
2013 Camaro SS 1LE - Black - M6 - Sold 2016 Camaro SS - Mosaic Black - A8 - Sold 2017 C7 Stingray - M7 Coupe - Sold 2019 C7 Grand Sport M7 Vert - Sold 2021 Camaro ZL1 - Black - A10 - Sold 2019 Tesla Model 3 2022 CT4-V Blackwing - M6 |
07-19-2016, 06:04 PM | #17 | |
Retired from Car mfrs....
Understand direct injection takes a few times to crank over to pressurize. That's why it seems like it takes longer to start , it's not the battery. |
07-19-2016, 06:19 PM | #18 |
Thanks for the reply. It was not so much the number of cranks but the the first initial crank seemed a bit weak a few times when I was running errands today. Seems more prevalent with a hot start. I know with the new smart charging tech it may not keep the battery fully charged at 12.6v all the time as it balances the electrical load between the alternator and battery, but I hope the smart charging tech will inform me if it does sense a low voltage condition.
07-19-2016, 06:38 PM | #19 |
Drives: 2016 2SS 6spd Join Date: Apr 2016
Mines not my daily driver so I got a tender I leave on it as I felt the initial crank was a little lazy as well
Wondering if the starter is a carryover from an LS and doesn't quite have the huevos for the higher compression LT1 |
07-19-2016, 06:43 PM | #20 | |
Drives: 2016 camaro 1ss Join Date: Mar 2016
2016 Camaro 1SS
M6, NPP, MRC, sunroof, black hashmarks, black bowties, Low gloss black 20" wheels |
07-19-2016, 07:15 PM | #21 |
Drives: 2016 Camaro 1LT Join Date: Apr 2016
The voltage will change when the battery is under load. Watch how far the voltage drops while the starter is cranking. That will tell you a lot more than what it is with no load. Also right after starting the car, the battery has had a tremendous load put on it, so the amps will be higher as it is recharging from the startup.
Life after retirement |
07-19-2016, 08:55 PM | #22 | |
07-19-2016, 11:06 PM | #23 |
Drives: 1LS MT Join Date: Feb 2014
A battery at 12.6 or 12.3 is a dead battery. Take a volt meter and measure right at the battery for accuracy. My 2 15 Camaros always showed charging between 13.4 and 13.8. This new 16 show charging of 12.4. Something is not right.
07-19-2016, 11:07 PM | #24 |
Totally wrong.......i'll let somebody else explain it to you
07-19-2016, 11:52 PM | #25 |
Didn't realize 12.3 or 12.6 volts is a dead battery in a 12 volt system. There's a difference between voltage when the alternator is charging and static charge when the alternator is not charging.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
07-20-2016, 11:06 AM | #26 |
Glen e, I just checked the battery before starting the car, it shows 13.76 volt. Trust me, if it is between 12-12.6 it is dead meat.
Been working on marine electrical systems for over 20 years now. |
07-20-2016, 01:36 PM | #27 |
I measured the voltage it at the jump terminals under the hood with a quality meter. Do you think that will make a difference vs. putting the meter directly on the terminals? They don't seem easy to access?
07-20-2016, 01:46 PM | #28 | |
You are checking the battery with the engine running .....I also have been marine systems for 20 years. You are reading the charging system ,not the battery Car batteries resting voltage is maxed at 12.7, once surface charge is removed. Educate yourself here : http://www.batteryfaq.org |
