09-09-2017, 09:35 AM | #1 |
Drives: 2022 SS 1LE Join Date: Aug 2017
Non-NPP vs. Stealth mode?
I haven't purchased yet and as much as I want a loud exhaust, I leave home early in the mornings and so to avoid waking kids in the roof above the garage and disturbing neighbors wanted to check if Stealth mode with NPP is quieter starting up than non-NPP?
Appreciate the irony but I'm almost more interested in NPP to have the option to make it quieter (will love it loud once I'm out on the road)! cheers, Pete. |
09-09-2017, 10:06 AM | #2 |
Yes, I have LTs going through the NPP suitcase. On the street I am in full time stealth mode and the start up is not too bad. In any standard setting the LT start up wakes the dead. Fun at the track, but not at home.
Without LTs the startup is still loud in any setting as I remember.
09-09-2017, 04:40 PM | #3 |
NPP stealth is definitely quieter than a stock SS exhaust from my experience.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
09-10-2017, 12:24 AM | #4 |
Many thanks - looks like NPP (either factory or equivalent aftermarket) will be required with the stock exhaust not being stealthy enough when I need it to be...
09-10-2017, 12:29 AM | #5 |
Npp stealth makes it hard to even tell it's a V8 under the hood.
2016 NFG 1SS A8
09-10-2017, 10:22 AM | #6 |
Drives: 2019 ZL-1 Join Date: Feb 2009
My experience is NPP is loud when first started no matter what mode. However I have not tried stealth.
2012 Yukon XL Denali w/ 6.2 AWD |
09-10-2017, 10:31 AM | #7 |
Drives: 2016 Camaro 2SS Join Date: Dec 2015
Stealth is the only mode that keeps the valves closed at startup. You're right, all other modes leave them open. You do have to go into stealth mode before turning the car off, I haven't found a way to change modes after the car has been turned off... that's annoying to be honest.
09-10-2017, 01:15 PM | #8 | |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
09-10-2017, 01:52 PM | #9 | |
I should really read the manual, huh...
09-10-2017, 01:54 PM | #10 |
Don't think it's in there. Service mode might be but not the trick to getting a stealth startup.
Sent from my SM-G950U using Tapatalk
09-10-2017, 01:56 PM | #11 | |
Drives: '16 Red Hot 2SS M6 NPP Join Date: Apr 2016
'16 2SS, M6, Borla Atak |
06-12-2018, 07:34 AM | #12 |
Drives: 2017 2SS Camaro Convertible Join Date: May 2018
I just did a quick search to reread this as I certainly don’t recall seeing it in the owners manual.....great info for a pre-6am ride out of my neighborhood this morning....thanks again Megahurtz!
06-12-2018, 08:05 AM | #13 |
All you have to do is turn the ignition on(press start with foot off the brake) and set the drive mode to snow/ice and it sets the exhaust to stealth mode.
2016 NFG 1SS A8
06-12-2018, 09:40 AM | #14 |
Drives: 2016 M6 Hyper Blue 2SS Join Date: May 2016
When in stealth the car still opens valves when you shut it down right? I know my car when in stealth mode when I shut it off the valves open up. But when I start it up it sorta starts loud then valves close, after about 1 second.
16 2SS M6 // Kooks 1- 7/8 w/Off Road Pipes // RotoFab w/Oiled filter // Custom Axle Back Exhaust // E-85 Sensor // Tuned SOLD!!
