02-06-2020, 04:17 PM | #1 |
Roof expert detail noob
Drives: 2013 BRM 2LT RS Join Date: Oct 2012
Front wheel ABS sensor
Just found out the front right wheel sensor crapped out on me after 135k miles. The nerve right..... I've looked far and wide on how to replace this myself, but have come up empty. The best I can find is the rear wheel sensor replacement for my 2013 Camaro, but I can only assume the front is different.
Can anyone point me in the right direction on how to replace this? I'd hate to bring this to a station and get nailed for a $300 or more bill when I know I can probably do this myself. Thanks!
02-06-2020, 06:00 PM | #2 |
Drives: 2015 Camaro Join Date: Aug 2018
I don't think it would be that much different, if any, from the rear. It's basically a electro magnetic sensor that bolts to the spindle facing the toothed reluctor wheel in the hub.
02-07-2020, 07:40 AM | #3 | |
02-07-2020, 08:35 AM | #4 |
$11.78 for the fronts. https://www.rockauto.com/en/catalog/...ed+sensor,1912
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
02-07-2020, 09:32 AM | #5 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
unplug it and It just unbolts from the knuckle and you pull it out. make sure you clean off any dirt and debris before pulling it out, insert new plug in and be on your way
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
02-07-2020, 05:06 PM | #6 |
Part ordered, thanks guys
John
02-11-2020, 02:59 PM | #7 |
Unfortunately the part did not do the trick unless I need to do a battery pull. Computer stated it was front right wheel sensor, but this might be a bit more complicated than just a sensor.
02-11-2020, 04:01 PM | #8 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
Did you drive it after you replaced the sensor?
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. |
02-11-2020, 06:04 PM | #9 |
For 2-3 miles only. Tomorrow I will put 80-90 miles on it.
02-12-2020, 01:59 PM | #10 |
Drives: 13 Camaro Join Date: Oct 2016
Tsb on this situation.
02-24-2020, 03:31 PM | #11 |
Thanks for this. My mechanic told me that if the sensor does not work, then there is probably build up in the hub that needs to be cleaned. I guess my next question is whether this is a fairly easy job to do myself?
