Old 12-13-2012, 02:12 AM   #1
CrystalRedTintcoat
CrystalRedTintcoat's Avatar
Drives: 2013 2SS 1LE NPP GBE
Break-in and Track Prep
Thoughts on the owner's manual for break in and Racing prep? See pages:
9-16
9-6
9-7
This is informational only. Only refer to and follow what's in the YOUR owner's book.
  • High performance brake fluid before racing
  • Rear axle fluid change after break in and before racing then after every 24 hours of racing
  • Rear differential cooler - optional if you do lots of racing
  • Brake burnishing (that will be a fun day!!!)
  • Full throttle starts
  • 4000 RPMs
  • Single speed driving
  • 80mph
  • Downshifting RPM limit
  • No racing
  • No hard cornering
  • No hard stop
CrystalRedTintcoat is offline   Reply With Quote
Old 12-13-2012, 01:43 PM   #2
Lumino1LE
Rally Yellow 2SS/RS/SR
Lumino1LE's Avatar
Drives: Born 11/12 2012 Camaro 2SS RS 1LE
Great info, CRT.
Does anyone have a .pdf of the owner's manual?
Lumino1LE is offline   Reply With Quote
Old 12-13-2012, 04:33 PM   #3
cornerspeed92
cornerspeed92's Avatar
Drives: 2013 1SS 1LE
9-16
9-6
9-7
  • 4000 RPMs
  • 80mph
  • No racing
  • No hard cornering
  • No hard stop
I read that too,and talked to my dealer about it.He said that they wouldn't send this car out if it wasn't track ready.We looked at the brake res. and it says dot 3,which isn't high performance fluid.I know the service director,and he is into high performance and seems to know what he is talking about,but i wonder.Does anyone have an informed answer to what if any thing should be done?
cornerspeed92 is offline   Reply With Quote
Old 12-13-2012, 05:33 PM   #4
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
Your dealer isn't into high performance if he's going to send you out to a track day in a 4000lb car with Delco Supreme II. You're going to boil that fluid quickly and find yourself with much less brake than you need. Frankly, I wouldn't go back to him after advice like that. You always track prep your car. I would go a step further and get a set of track pads as well.
Also, it wouldn't hurt to flush your diff after your first track day. You're going to be putting it through more abuse than most street cars see in a lifetime.
What is this, CorvetteForum Lite?
LSxJunkie is offline   Reply With Quote
Old 12-13-2012, 06:35 PM   #5
cornerspeed92
Thanks
Old 12-13-2012, 06:39 PM   #6
Synner
Drives: cars
+1
He's never raced anything.
Synner is offline   Reply With Quote
Old 12-13-2012, 06:59 PM   #7
tramtwo
tramtwo's Avatar
Drives: 2021 1LE
If this car was track ready it would not have the brakes and clutch sharing the same reservoir .
tramtwo is offline   Reply With Quote
Old 12-13-2012, 08:08 PM   #8
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
+1
I use Motul 600 which is DOT 4 and a racing brake fluid and still had brake fade at the end of the day. That OE DOT3 stuff will do OK for parking lot racing, but on a track it will fail. You will find if you track, you're going to need to bleed brakes often to refresh the fluid and change out once a year. You should also change rear diff fluid more frequently too. I dumped my rear diff fluid at 2500 miles with no racing at that point. I was surprised at the amount of metal that was stuck to the magnetic plug. I'm changing mine now at 10 hours of track use.
bannonm is offline   Reply With Quote
Old 12-14-2012, 06:59 AM   #9
LSxJunkie
Snark snark snark
LSxJunkie's Avatar
Drives: RX350
Originally Posted by bannonm View Post
+1
Are you running cooling ducts? What pads?
Old 12-14-2012, 10:11 AM   #10
dirkdoesdirt
dirkdoesdirt's Avatar
Drives: 2010 Silverado, Ordered 1LE
Originally Posted by Lumino1LE View Post
Great info, CRT.
On the Canada site, go to the search box and put in ""Owners Centre"
Then enter 2013 Camaro and scroll down. You will see a dnld 'able pdf of the owners manual
dirkdoesdirt is offline   Reply With Quote
Old 12-14-2012, 10:24 AM   #11
LRJet35
LRJet35's Avatar
Drives: 2013 2SS RS 1LE
Great info, CRT.
2013 Camaro Coupe owners manual
LRJet35 is offline   Reply With Quote
Old 12-14-2012, 01:26 PM   #12
VR1LE
lighten up Francis
VR1LE's Avatar
Drives: 2013 Camaro 1LE
I am putting in Motul RBF600 and breaking in at the track. That is a long list on my current track car I do only brake fluid and oil changes every 100 laps
1SS 1LE track rat ordered 10/19
Arrived at dealer 12/26/12 after hours delivery
VR1LE is offline   Reply With Quote
Old 12-14-2012, 05:26 PM   #13
Lumino1LE
Lumino1LE's Avatar
Originally Posted by LRJet35 View Post
Thank you LRJet.
Old 12-14-2012, 06:13 PM   #14
cornerspeed92
This is all good info,and has me thinking.I put a thread on the ZL1 guys and asked what was in their cars,and they said DOT 3 as well.One guy said they ship with DOT 3 cause moisture absorbs faster in DOT 4,but they switched.As i was so patiently(not really it was hell waiting for something so cool)waiting for my 1LE, everything i read about write up's about this car, was no brake fade even after being on the track all day.
