03-18-2018, 08:27 PM | #1 |
Drives: 2016 Chevy Camaro Join Date: Feb 2016
Brake Fluid service?
Hello all,
I went to the dealer the other day and they recommended allot of things for my 2016 Camaro with 40,000 miles on it. One of those things was a brake fluid service. I checked the manual and this is recommended at 5 years. Can you think of any reason why it would be recommended to do this early? Should I consider it? The recommended fuel induction service I've figured out is basically useless unless you have a problem. I can do the air filter and cabin filter myself. And I'm going to price check the tire cost. What do you think? Would you even consider the brake fluid service for $120? I don't race or anything. Thank you, Whiskey |
03-18-2018, 08:57 PM | #2 |
Thank you Al Oppenheiser!
Obey the manual, not the stealership.
03-18-2018, 09:20 PM | #3 |
Drives: none Join Date: Nov 2012
brake fluid absorbs water from the air...its hygroscopic...
There is some brake fluid(Castrol RBF) that recommends it be changed yearly because of how much water it can absorb from the air. Some of the other high performance stuff recommends a 2 year swap. Factory fluid aint that great so it is probably pretty low on the hygroscopic level. So 5 years is probably good enough. The systems are ALMOST sealed, but obviously some air and thus moisture can get in. BUT if you want it done, I wouldnt say $120 is a terrible price as they will hook it up to the Tech 2 to bleed the ABS module. $20 in fluid and an hour of shop time. I wouldnt do it at the 2 year mark personally on a daily driver type vehicle. Hell I probably wouldnt do it at the 5 year mark(I only put around 10k a year on my daily driver). Do it when you need brakes which will probably be at between 60 and 80k miles... |
03-19-2018, 04:14 AM | #4 |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Sep 2014
Every 2 years regardless of mileage has always been the golden rule.
03-19-2018, 05:11 AM | #5 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
I've had cars with 120k on the factory brake fluid with zero issues.
You can change the fluid whenever and as often as you like but it's not detrimental. |
03-19-2018, 05:54 AM | #6 |
Drives: 2017 Camaro 2SS, A8 Join Date: Aug 2017
I've had and have cars with 20 and 30 year old break fluid that are fine, stop on a dime. Maybe the newer brake fluid isn't that good or just a precaution.
03-19-2018, 08:03 AM | #7 |
HYPER SS
Drives: 2016 Supercharged 2SS Join Date: Feb 2014
This..
Ordered: 1/15/2016
2000 status 02/01/16 3000 status 02/29/16 3400 status 03/07/16 TPW of 03/14/16 4200 status 03/17/16 in transit! Delivered 03/23/16 2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points. | AWE touring - resinated catback with link pipes. |
03-19-2018, 11:34 AM | #8 |
It sounds like this is still the topic of some debate. I think I will hold off and flush the system when I need to replace my brake pads which should be before the 5 year mark. I've always done the two together since I'm already in there.
Thank you for the advice! Whiskey |
03-19-2018, 01:03 PM | #9 |
Drives: 2001 Onyx Black/Ebony SS. 427/M6 Join Date: Apr 2016
As a Mercedes tech, I can tell you that they recommend every 2 years or 20k. Even the bottle states every two years. I read the manual on my Colorado this weekend and it also states every 5 years. I get it, you see it all the time, cars with 200k on the original brake fluid, but it is black and nasty. If it were in a truck, I wouldnt recommend towing with it. Gotta remember too, it also acts a lubricant for the seals in your master cylinder and calipers. Plus the hygroscopic properties can cause rust of the brake lines from the inside out. As stated above, stick with what the manual says, not the dealer. I also see it this way, you cant over maintain your car, but you sure can under maintain it. For me, my Colorado say to change the transmission fluid at 97.5k for "normal" use and 47.5k for "severe" use. I like to pick an easy mileage to follow, so I'll just do mine every 40k. Engine oil changes state every 7.5k, I just do it every 5k. Easy to follow and since GM has had issues in the past with the Oil Life Monitor algorithms on other models, I dont trust that.
03-19-2018, 06:53 PM | #10 |
376 cubic inches of fun
03-19-2018, 06:57 PM | #11 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
I plan on doing it this year, so that would be 2 years.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
03-19-2018, 07:58 PM | #12 |
Are these sharing the reservoir with the clutch? I think they are, right? I’m doing it this weekend so I’ll find out then.
But yeah If u have a manual and it shares I would change more frequently for sure |
03-20-2018, 07:51 AM | #13 |
HYPER SS
yes, if you have a manual, it does share the same with brake fluid. to me, that would be even more reason to change it sooner.
Ordered: 1/15/2016
03-20-2018, 01:13 PM | #14 |
Drives: 2015 Camaro 1SS Join Date: Dec 2017
