06-09-2017, 04:14 PM | #15 |
Drives: 2019 Silverado Z71 6.2L A10 Join Date: Mar 2017
Have fun and hold on your ass
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's. Past Rides 2017 M6 Camaro ZL1 Hyper Blue 2016 M6 GT350 White with blue strips 2014 M6 Mustang GT Premium Track Pack Ruby Red 2012 M6 M3 Melbourne Red Metallic |
06-09-2017, 04:43 PM | #16 |
Drives: 6th. Gen ZL1 Join Date: Jan 2017
06-09-2017, 04:56 PM | #17 |
Drives: 2017 zl1 conv 6 sp- '18 trackhawk Join Date: May 2017
tuff to hold yer ass and shift at same time
- yea..i have a manual..i'll call the local chevy dealer on monday and ask them what they wanna do...good stuff guys..thx for the replies..GREAT community |
06-09-2017, 05:29 PM | #18 |
You mean you do not whisper sweet nothings to your Recaros' during high G turns, telling her how nicely she holds on to your ass? I do.......Wait, i mean i'm just kidding.
06-09-2017, 05:57 PM | #19 |
ummm..sure......yea...u were just joking...we know that
06-09-2017, 10:26 PM | #20 |
Drives: 2017 ZL1 Garnet Red Join Date: Feb 2015
I did mine at 553 miles and 1561 miles. Dealer used Mobil 1 on both oil changes. Also changed the rear gear fluid 1561 miles. Car runs fantastic.
06-11-2017, 01:13 AM | #21 |
Drives: Duramax Join Date: May 2017
This is an excerpt from the Chevrolet LT4 Performance Installation Manual about the oil priming and initial break-in procedure.
https://www.chevrolet.com/content/da...p-19332622.pdf Start-up and Break-in Procedures Use only engine oil licensed to the dexos1® specification of the proper SAE viscosity grade. AC Delco dexos1 Synthetic Blend is recommended. For track events or competitive driving, use Mobil 1® 15W-50 engine oil. Safety first, if the vehicle is on the ground, be sure the park brake is set, the wheels are chocked and the car cannot fall into gear. Verify everything is installed properly and nothing was missed. This engine assembly needs to be filled with oil. After installing the engine, ensure the crankcase has been filled with the appropriate motor oil to the recommended oil fill level on the dipstick. This crate engine require a special oil meeting dexos1. Also check and fill as required any other necessary fluids such as coolant, power steering fluid, etc. The engine should be primed with oil before starting. Install an oil pressure gauge (there is a plugged port that can be used to mechanically measure oil pressure and used to force prime the system using Kent More J45299 priming tool, see Figure 9/10) When possible, you should always allow the engine to warm up prior to driving. It is a good practice to allow the oil sump and water temperature to reach 180°F before towing heavy loads or performing hard acceleration runs. The engine should be driven at varying loads and conditions for the first 30 miles or one hour without wide open throttle (WOT) or sustained high RPM accelerations. Run five or six medium throttle (50%) accelerations to about 4000 RPM and back to idle (0% throttle) in gear . Run two or three hard throttle (WOT 100%) accelerations to about 4000 RPM and back to idle (0% throttle) in gear. Change the oil and filter. Replace the oil per the specification in step 1, and replace the filter with a new PF64 AC Delco oil filter. Inspect the oil and the oil filter for any foreign particles to ensure that the engine is functioning properly. Drive the next 500 miles (12 to 15 engine hours) under normal conditions. Do not run the engine at its maximum rated engine speed. Also, do not expose the engine to extended periods of high load. Change the oil and filter. Again, inspect the oil and oil filter for any foreign particles to ensure that the engine is functioning properly. END I always wonder about the new cars that are being test driven. I doubt the Dealer adheres to this break-in procedure from GM Engineering. |
06-11-2017, 05:55 AM | #22 |
When I had my first Camaro (2011) The guys on here (Camaro5) were suggesting changing the Trans (M6) and diff fluid to Royal Purple.
The fluid I drained out was BLACK and smelled like fish even at early miles. After the change I could actually feel improved shifting. What do you guys think?
06-23-2017, 12:20 PM | #23 |
Just wanted to say that the GM recommended oil for the ZL1 is on sale at Costco... very good price..
Current ride
06-24-2017, 10:29 PM | #24 |
Drives: 1967 RS 327 Muncie, 2017 ZL1 6spd Join Date: Jan 2017
I changed my oil at 98 miles and again at 501 miles and I'm glad I did. Both times it was dirty. Definitely not clear at all and a decent amount of metallic flake visible under a bright light.
02-18-2018, 06:55 PM | #25 |
Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel Join Date: Oct 2017
Well, the 2017 and 2018 Camaro track prep guide recommends first oil change at 500 miles. No idea why the owners manual and high performance supplement doesn't say the same.
02-18-2018, 10:17 PM | #26 |
Drives: ZL1 Join Date: Jun 2012
Did mine at 500.
2018 ZL1 Vert
2018 Dodge Demon |
02-18-2018, 10:32 PM | #27 | |
Drives: A10 LT4 Join Date: Aug 2016
Lots of miscommunication... |
02-19-2018, 05:47 AM | #28 |
Drives: 2014 Jeep SRT/2017 ZL1 Join Date: Mar 2017
My salesman also reminded me at 500 I listened and did it also, was for free so no skin off my back...
