Old 06-24-2014, 09:50 PM   #1
NicksVSix
NicksVSix's Avatar
Drives: 2014 2LT Red Rock Metallic
What's the difference between these two kits?
Hey guys,
Well, my wife got a bit confused and "only" got me a PC7424XP for my birthday, so now it's up to me to get pads and polishes.
I am 99% going to get Adam's polishes, but I am leaning heavily towards getting 5.5" pads and a 5" backing plate, based on all your advice.
My one big question now is what's the difference between these two kits?
http://www.eshine.ca/lake_country_cu...236.php?cat=27
http://www.eshine.ca/lake_country_cu...241.php?cat=27
One says CCS and the other says FLAT.
What's the difference between the two and what would you all say is better for a PC?
Thanks!
Nick
NicksVSix is offline   Reply With Quote
Old 06-24-2014, 09:51 PM   #2
CamaroDreams07
CamaroDreams07's Avatar
Drives: Slow V6
You want flat.
Sent from my HTC One using Tapatalk
[B]
CamaroDreams07 is offline   Reply With Quote
Old 06-24-2014, 09:52 PM   #3
NicksVSix
NicksVSix's Avatar
Originally Posted by CamaroDreams07 View Post
You want flat.
OK, cool, thanks.
What's the difference, anyway?
Old 06-24-2014, 09:59 PM   #4
CamaroDreams07
Drives: Slow V6
The surface of the pad. The CCS is dimpled for heat dispersion. The flat is flat for maximum contact area. You want the flat for most DA applications as you don't need the heat reduction and you'd rather have more contact area.
[B]
Old 06-24-2014, 10:03 PM   #5
NicksVSix
NicksVSix's Avatar
Thanks for the explanation!
Was is you that was recommending the FG400 as a multi-purpose paint correcter and polish? The website I linked above carries it. What pads would you recommend I get to use with that? Orange and white, just as if I went with Adam's products?
Cheers!
Old 06-24-2014, 11:14 PM   #6
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Yes FG400 can be used as a one and done product. You just have to learn to finish with it, to get the best finish possible.
If you're sticking with foam pads, orange is what most use for the grunt work. White is a less abrasive so it should be used with your second step products, if you use them. Black, blue, red, and gold are marketed as having no cutting ability so they should be used for spreading waxes, sealants, and glazes. You'll need a couple of oranges, and a couple of the waxing pads, if you plan to use them. Personally, I do my sealants and waxes by hand. For glazes I use a machine/black pad. If you want the best cutting available, get the microfiber pads. I see that eShine has the optimum MF pads which should be fine. If you go that route, you'll need a couple of them, along with a pad brush.
MF pads
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
I once parallel parked a train.
axis is offline   Reply With Quote
Old 06-25-2014, 07:01 AM   #7
NicksVSix
NicksVSix's Avatar
Could I get away with just using FG400 on microfibre and orange pads and then finish the job with applying a sealant/wax by hand, or will I need something in between?
Old 06-25-2014, 07:37 AM   #8
CamaroDreams07
Drives: Slow V6
Explain your process. Why are you doing microfiber and foam pads?
[B]
Old 06-25-2014, 10:19 AM   #9
NicksVSix
NicksVSix's Avatar
I won't be necessarily.
I will be finishing the process with Adam's Sealant (the grey stuff) with a black pad and by hand, depending on where it's being applied.
Before that, the jury's still undecided. I was *thinking* of using the Lake Country, orange and white, with Adam's orange and white polishes, respectively, but if I can use FG400 as the only product before the two Adam's polishes, I'm open to that idea as well. I'm just not sure what pads to use with that product.
Cheers!
Old 06-25-2014, 10:34 AM   #10
DylanVK
Drives: a few
Shouldn't need all 3 polishes you're mentioning... depending on the condition the paint is in to start with you may be able to correct with 1 and refine with another.
In some cases, if you work it right, 1 step will get most people to a very happy place.
1967 C/10 PROJECT TRUCK | DETAILING EXPERT | CRAFT BEER ENTHUSIAST
DylanVK is offline   Reply With Quote
Old 06-25-2014, 10:43 AM   #11
NicksVSix
NicksVSix's Avatar
Overall my paint is in very good condition. The car is only 2+ months old, but there's more scratches and swirls in the paint than I would like for a 2 month old car.
Minimal correction is required, but it's still required. I also want to try my hand at correcting the paint on my wife's black Kia Optima. Swirl city.
Old 06-25-2014, 12:09 PM   #12
NicksVSix
NicksVSix's Avatar
If I were to use FG400 as my only product before applying Adam's sealant by hand, what pads should I get?
All orange? 2 orange and 1 white?
Old 06-25-2014, 01:31 PM   #13
CamaroDreams07
Drives: Slow V6
You still haven't addressed why you mentioned microfiber pads.
Are you using microfiber or foam?
[B]
Old 06-25-2014, 01:39 PM   #14
NicksVSix
NicksVSix's Avatar
Leaning heavily towards foam.
