Old 07-28-2014, 09:57 AM   #1
Powhusku
Powhusku's Avatar
Drives: 2010 2SS/RS M6
Talking Vortech V-3Si w/ LG G6X3 Cam Dyno Results
So we finally got the car on a dyno yesterday. This is to showcase how an LG G6X3 (naturally aspirated cam) deals with F/I.
Here's the sheet from before the supercharger. Cam and headers w/ high flow cats were installed at the time.
And here it is the results with the supercharger+supporting mods.
The Vortech kit came from RMCR and was painted by them. Neither dyno test had a fan in use, so we expect a little more air and some tuning could put this car at 800 RWHP. It is still stock bottom end. Gearing is 3.91. The car runs great and is a blast to drive. For clarification, the stickers all over the car are from a 4000 mile road rally I just got back from. Yes the supercharger was on and the car didn't even hiccup.
Supporting mods include:
60 lb. Injectors
ZL1 Fuel Pump
ADM FPMC
ZR1 3-Bar MAP Sensor
Corsa ZL1 3" Catback
Elite Engineering 2nd Gen Catch Can
BBK High Flow Fuel Rails
Kooks 1 7/8" LT's
No Cats
More info/pictures and additional supporting mods can be found in my build thread. Just click on my sig.
Powhusku is offline   Reply With Quote
Old 07-28-2014, 10:33 AM   #2
alssiri
alssiri's Avatar
Drives: 2017 ZL1 A10
Great setup & great result enjoy it
Ahmad
2017 ZL1 A10 SW (SOLD)
Whipple 2.9 with 3.2 Pulley, Weapon-X Stage 3 Cam, FIICHILLER ,LG Motorsports LT, Borla S type, ROTFAB Big Gulp, Big 3 Reservoir
Glassskinz rear window valance .
2012 ZL1 A6 (SOLD)
Forged 376 CI, LSA HeartBeat, Mast Medium Bore Heads & JDP ZLR Cam, ARH LT , MagnaFlow Resonated X + Borla Atak Catback, ADM 102mm Snout, CAI, NW102MM TB, ID850, Fore Triple Fuel Pump, MSD Wire's, Moroso CC.
Alky Control, FIICHILLER.
alssiri is offline   Reply With Quote
Old 07-28-2014, 02:59 PM   #3
bct10985
Drives: 2010 2SS LS3, 2013 duramax
Was fuel pressure dropping? Cant see the zl1 pump and adm fpcm hold pressure at that hp level. Meth?
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
bct10985 is offline   Reply With Quote
Old 07-28-2014, 04:04 PM   #4
Powhusku
Powhusku's Avatar
No meth. I didnt get to observe any parameters since this was just a trailer dyno at a show (same trailer dyno as the old sheet). We'll rent some tuning time on it in the near future and check everything out. I was as surprised as you are that it made those numbers. We did 3 pulls and hp/tq was dropping each time. I assume that was caused by heat since it was hot out and we didn't have a fan.
Old 07-28-2014, 04:58 PM   #5
Unreal
Drives: 2006 Z06
Fuel pump/etc doesn't care about correction factor. Look at the sheet, it has a 33% correction. Actual power is ~589rwhp so fueling shouldn't be an issue with that setup.
Nick
Corvette Z06 -1200ish rwhp
Unreal is offline   Reply With Quote
Old 07-28-2014, 05:30 PM   #6
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Makes much more sense esp. with the 60# injectors
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 07-28-2014, 05:34 PM   #7
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
so is the first run n/a and it looks to be dead on. but corrected is whats need if ur at high altitude right.
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 07-28-2014, 05:37 PM   #8
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
^^^what he said.
2001 ws6, 40k miles, Ls3 416 stroker, short block built by PER the rest by me. LPE Ls3 heads milled to 12-1 comp, FAST 102, NW 102, kooks 2", dual DMH cutouts, Magnaflow C/B, BTR cam + springs. Full UMI suspension.
litle88 is offline   Reply With Quote
Old 07-28-2014, 05:38 PM   #9
litle88
V8 Lounge member #2
litle88's Avatar
Drives: 2001 Ws6
How much boost?
Old 07-28-2014, 07:48 PM   #10
Nitroman28
Nitroman28's Avatar
Drives: 2010 Camaro SS 416/4L80
I have 60lb injectors and around 650rwhp and IDC is 73% down the track. I think I could get 700 with these injectors. I do have a Squash setup.
Nitroman28 is offline   Reply With Quote
Old 07-29-2014, 12:07 AM   #11
Detoxx03
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Detoxx03's Avatar
Drives: 2008 Corvette
D1SC Procharger 932/758 on E85
A Futral Motorsports Creation
https://www.facebook.com/DetoxxAtomic
Detoxx03 is offline   Reply With Quote
Old 07-29-2014, 09:53 AM   #12
That_Guy
That_Guy's Avatar
Drives: n/a
I'm not sure I follow, are you suggesting that his pre supercharger run was only 300 hp also? The correction factor wasn't changed. Looks to me like they probably use a weird brand dyno and use 1.33 to convert to dynojet numbers.
That_Guy is offline   Reply With Quote
Old 07-29-2014, 09:54 AM   #13
That_Guy
That_Guy's Avatar
Drives: n/a
I don't think that setup will provide enough fuel at that power though, it's probably on the ragged edge
Old 07-29-2014, 10:12 AM   #14
Unreal
Drives: 2006 Z06
Looks like Colorado. High elevation places have huge corrections and they mess with FI.
So yes, preblower he was making 336rwhp. That is a dyno jet, not conversion to a dynojet. The block, fuel, pistons, clutch, axles, etc don't care about corrections, just actual power. Funny seeing places at high elevation say how they are making 700-800rwhp on stock motors/etc when in reality they are making 150-200rwhp less without the correction.
Nick
