dave@hennessey
Old 09-28-2018, 07:33 AM   #1
Niceun
Niceun's Avatar
Drives: 2012 45th edition RS 2LT
Leaky trunk fix
Hey fellas with all the rain we’ve been having here where I live I thought maybe some of you guys have encountered the same issue I did and that is a trunk that leaks. I think I found the fix. It is a drain tube located inside the trunk on either side up towards the rear shelf. In my car the tube was not inserted completely into the nipple that leads to the outside. I have attached a couple of pictures. One shows the disconnect and the other show the connected. Hope this helps out. Cheers.
MG]
Niceun is offline   Reply With Quote
Old 09-28-2018, 07:35 AM   #2
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
That would be from the sunroof...…...
christianchevell is offline   Reply With Quote
Old 09-28-2018, 02:56 PM   #3
Gordo-D
Gordo-D's Avatar
Drives: 2015 Camaro 2SS
That's not good, glad in a way my latest one hasn't got a sunroof.
Gordo-D is offline   Reply With Quote
Old 09-28-2018, 03:02 PM   #4
L6611983
Drives: 2010 Camaro 2SS
Tube
I'm having the same problem, where can I purchase that drain tube? mine is missing.
L6611983 is offline   Reply With Quote
Old 09-28-2018, 03:06 PM   #5
witenite
witenite's Avatar
Drives: 2010 2SS non RS
Op, if you only connected back still keep an eye on it. If it's like mine it will continue to come disconnected on it's own. Mine happens to always be the passenger side. You may have to put a clamp, zip tie or something around it to keep it connected.
Old 09-28-2018, 04:56 PM   #6
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
I would have put some silicone weather strip glue on it to hold it in place...
The Bird is the word!
Old 09-29-2018, 12:04 PM   #7
Niceun
Niceun's Avatar
Good ideas guys. I will definitely do one of them. As far as where to purchase the drain tube I have no idea. Maybe the auto parts store would have some type of tube that would work.
Old 09-29-2018, 05:48 PM   #8
Whoomba
Drives: 2024Camaro 2SS CE Convertible
Yeah, checked that. It was connected in mine. The only thing I think of is I had the trunk packed too tight and had the bag pushed up. Hasnt done it since.
Old 09-29-2018, 10:57 PM   #9
IlikeMyCamaro
Drives: 2010 2LT/RS
I had that problem with my trunk too, I just bought a 1/2" tubing and connected the two so it wouldn't disconnect again. The tubing from the sunroof on that side just seemed too short, it would barely connect.
IlikeMyCamaro is offline   Reply With Quote
Old 09-30-2018, 08:14 PM   #10
94z28inok
Camaro- Life Member
94z28inok's Avatar
Drives: 15 Camaro 2SS/RS, 19 Tahoe
Send a message via Yahoo to 94z28inok
I used bicycle tire patch glue and a small zip tie on mine, no leaks in over a year.
15 2SS/RS LS3 M6 Summit white
16 200 40mpg Vivid Blue Pearl
19 Tahoe 5.3 Boring Grey
91 Camaro RS 305 TBI 700R4
85 Corvette - TBD
05 Envoy 4.2 4x4
94z28inok is offline   Reply With Quote
