02-07-2017, 11:47 PM | #1 |
Tire Upgrade
what would be the cheapest option to upgrade to 20 inch rims and tires that are speed rated for 155 if I currently have the stock 18 inch LS rims and tires that are limited to 118? I'm looking for something that will last too
02-08-2017, 12:38 AM | #2 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
Interesting question! I can't provide you an answer but you may net better results if you try posting that here: http://www.camaro5.com/forums/forumdisplay.php?f=28
Thats our dedicated subthread to helping all wheels/tire talk. Good luck!
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
02-08-2017, 01:16 AM | #3 |
"BEASTM*DE"
BFG's Comp 2 A/S if your looking for tires and driving it daily 45,000 mile tire highest speed rating, excellent in rain, cold weather, smooth ride and quiet tire...
Vengeance Racing Stage 1 Kit 575rwhp, 569 rwtq...
Rims powder coated gloss black...BFG'S Comp 2 A/S... Dual 10" Kicker Comp S Subs 1200w... |
02-08-2017, 05:17 AM | #4 |
Master of All Things
Drives: '20 Corvette Stingray Join Date: Jul 2009
I went with GENERALs ASO3's and am very very satisfied. Not only do thay wear well, have good wet/dry traction, they are All Seasons on top of that. I got 45000 out of my first set.
oh and on top of that, I brought a full set (4) of rear wheels so I run 20 x 9's all the way around and 275/40's on all four corners. the handling is a lot better AND you can rotate your tires as well!
02-08-2017, 06:15 AM | #5 |
Drives: 2011 ss Join Date: Sep 2015
I'd go look somewhere like Facebook marketplace for local results. Here i Can find 20 inch rs wheels for 150 to 400 bucks. May find some aftermarket there too.
Discount tire has always treated ne right and haggle when buying wheel tire combos. Maybe get you some oe replicas and nitto for a reasonable cost. |
Tags |
rims, tires |
