02-14-2018, 08:08 AM | #57 | |
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85 Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE 10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake Best 1/8 6.80@105.75 Best MPH 134.82 |
02-14-2018, 11:54 AM | #58 |
Drives: 13' 1LE Join Date: Apr 2012
I think we should think about our 5.0 friends; camming their engine is like 10-15rwhp and cost a bunch. They all run lightweight flywheel, driveshaft, weight reduction, 15" drag wheels and agressive gearing. How often do you see this here? Not so often. they rev their engine higher and higher.
On the LS community, most average joe, like me lol, it seems that we take the easy route, because its easy, it works and its cheap. But its about to change! But for a max effort setup, its not gonna cut it. Max effort with LS3 intake...is a bit, lets say self defeating. I mean it works great with the rod mod and light porting, but you need something better to push the envelope. Lazermontana said it well. All those extra on the sides are the one that will pay in the end. Vacuum pump, electric water pump, notching the piston, 7500rpm and suporting intake manifold and some good e85... We gotta thank guys that are pushing it!! Gpi will be back with another record I hope!!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
02-14-2018, 12:27 PM | #59 | |
Drives: 2010 Camaro SS/RS Join Date: Mar 2014
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53 |
Tags |
aspirated, bolt-on, ls3, naturally, stroke |
Thread Tools | |
