dave@hennessey
Old 03-23-2020, 06:28 PM   #15
Safwan
Drives: Chevrolet camaro ss
Check fuel line connctors under the abs module do not crank just turn the ignition key to build up pressure then check them wet or dry if wet may be a cracked hose or faulty fitting seal
Safwan is offline   Reply With Quote
Old 03-24-2020, 12:56 PM   #16
LilyAnna
LilyAnna's Avatar
Drives: 2013 Camaro LFX 2LT
Thank you, everyone, for pitching your ideas as to what could be wrong.
All injectors are working fine but there is an apparent leak in the injector O rings, leaking O rings are being replaced today and the car will be tested to confirm all is well now.
I'll post back to confirm the diagnostic and if it has been fixed.
LilyAnna is offline   Reply With Quote
Old 03-25-2020, 01:17 PM   #17
LilyAnna
LilyAnna's Avatar
So it was just a leak from the upper intake manifold seals, they replaced the seal and she's back home alive and well.
Luckily it was just that and not something more expensive () as I had just spent quite some money on 6 brand new injectors and mechanic's bill
Sincerely, thank you all for your help!
Old 03-25-2020, 02:15 PM   #18
fhrex
fhrex's Avatar
Drives: 2011 Camaro 2LT/RS
congrats!
fhrex is offline   Reply With Quote
Old 03-26-2020, 06:52 PM   #19
RJT Impala
Stovebolt BluFlame 6
RJT Impala's Avatar
Drives: '12 2LT/RS, IBM; '20 Traverse Prem
Glad you got it solved and that it was an easy (relatively) fix!
RJT Impala is offline   Reply With Quote
fuel injection, fuel pressure, gas smell, injectors, rough engine
