Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Engine | Drivetrain | Powertrain Technical Discussions > Camaro V6 LFX Engine, Exhaust, and Bolt-Ons
Old 03-04-2020, 07:54 PM   #1
nickbettschen
Drives: 2020 Camaro 2SS Convertible
What next?
Hey guys,
So my upgrades so far are high flow cats, cat back exhaust, and cold air intake and a tune
What else is out there that you would recommend. That's worth it.
I was Thinking since my breaks are coming up maybe an upgrade any that are recommended?
nickbettschen is offline   Reply With Quote
Old 03-04-2020, 08:15 PM   #2
Bigdumogre
Bigdumogre's Avatar
Drives: 2012 Camaro SS
Long tube headers
Catch can
Plugs and wires
Ported throttle body
Rod mod and ported intake
Suspension upgrades like struts,lowering springs and trailing arms
Slotted rotors
Trans dip stick mod and service
Rear gears
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
Bigdumogre is offline   Reply With Quote
Old 03-05-2020, 02:44 AM   #3
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Originally Posted by nickbettschen View Post
Hey guys,
Have you looked over this thread yet?
https://www.camaro5.com/forums/showthread.php?t=222713
I know I have a LLT slightly different, but if you are interested in a 10 year build plan (I have not update my thread a in while, check out my signature link below).
Enjoy and good luck.
Originally Posted by Bigdumogre View Post
Long tube headers
Catch can
Plugs and wires
Slotted rotors
Rear gears
Always interesting to see V8 people offering advice to a V6 person.
Probably didn't realize he was in the wrong thread.
As you know there is no chance for long tube headers on the LFX V6.
Also, the Trans dip stick mod does not work for the V6.
rtcat600man is offline   Reply With Quote
Old 03-05-2020, 04:42 AM   #4
SIM GhostrdrZ
SIM GhostrdrZ's Avatar
Drives: ‘14 Z/28 ‘14 ZL1 M6 vert
I’ll try to remember all my mods:
Engine:
Will@overkill for tune, 80mm tb(he tunes for the new tb) patience is needed as he’s in Canada and is on his own schedule.
Ported and matched intake
Extender for intake
CAI, I have k&n but any seem good
Catch can, no gain but it does catch oil
Excellent oil for engine, trans and differential(amsoil & redline), remember the M6 trans takes gear oil not the same as the tr6060 ATF oil.
Cat back exhaust of choice, I prefer corsa
Aftermarket shifter
You can do mace cams and FI but I chose not to because of reliability questions
Suspension:
Replace almost everything with quality aftermarket, I used BMR or just get a 1le or z28 kit. I put coilovers on and it’s great to adjust height and ride quality.
Sway bars, I used Hotchkiss, but anything is better than stock.
Factory shock tower bar
Rear cradle bushings, I have pro BMR(have solids that I probably won’t put in)
Brakes:
Replace with Brembo from SS
Replace master cylinder with SS, only 2 used(v6 & v8)
M6; get separate clutch fluid reservoir
I put much more in but those are a few suggestions from a V6 installer
After I got and drove my Z28 then put it away for winter. The weather broke for a few days so I pulled out my V6 and forgot just how fun it was as well. The suspension is just as capable as the Z( with everything upgraded on v6) and the engine does fantastic for the little powerhouse it is. I also put lightweight wheels and 285/35/20 on all corners. It pulls 1+ G’s with Michelin all seasons.
SIM GhostrdrZ is offline   Reply With Quote
Old 03-05-2020, 04:35 PM   #5
xstuntman
Drives: 2012 Victory Red LFX
Not really performance related but if yours is a DD I would consider ceramic coating.
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
xstuntman is offline   Reply With Quote
Old 03-06-2020, 08:00 AM   #6
nickbettschen
Not a Daily but got it buffed up and coating done last summer made it look amazing!
Old 03-11-2020, 09:49 PM   #7
67-LS1
67-LS1's Avatar
Drives: 1966 Chevelle
Few better ways to improve all around performance than dropping weight
67-LS1 is offline   Reply With Quote
