Old 02-22-2020, 10:39 AM   #1
Suzies SS
Suzies SS's Avatar
Drives: 2013 Camaro SS
coolant leak
Our 2013 SS has a small leak ( coolant ) so small there is no evidence on garage floor. Our local mechanic found it, there is a service bulletin ( PIP4735D ) but even with only 22,000 miles Chevy wont warranty this. Our mechanic is ordering special tools to do the repair, will keep you posted.
Suzies SS is offline   Reply With Quote
Old 02-22-2020, 11:11 AM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Is it the leak at the oil cooler block ?? If so I went thru that one too and had to order a tap to clean out the threads where the fitting goes into the side of the block. Not a bad job, I think about an hour is what they charged me..Good luck..
1JEWLDSSRS is offline   Reply With Quote
Old 02-22-2020, 01:22 PM   #3
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
Mine has a similar issue. Never leaks off the car. It is weeping from around the entire top tank crimp. I knew because you can smell it whenever the car gets hot but I have no other issues with it so far.
Did they tell you where it is leaking from?
InFiD3ViL is offline   Reply With Quote
Old 02-22-2020, 01:48 PM   #4
Suzies SS
Suzies SS's Avatar
Yep, thats the same leak, the service bulletin was from 2102, not bad enough for a re-call I guess.
Old 02-22-2020, 01:53 PM   #5
Suzies SS
Suzies SS's Avatar
I had suspicions about that crimp around the tank also, am researching an all aluminum replacement. Kinda pricey but probably a good investment, this will probably be our last car. gettin old
Old 02-22-2020, 05:25 PM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yea, glad that's all it was. Yea they said they didn't do a recall because it didn't happen on a lot of engines, only some. I was told the tap used to "clean out" the threads in the aluminum block where the fitting goes into came from overseas, lol. I got lucky and 1 of my techs had 1 in his tool box, got it fixed the same day !
Old 02-22-2020, 07:34 PM   #7
BoloYang6
Drives: Camaro LT 2012
Camaro 2012 - Mine leaked at "gear" box - they notice it's from coolant pump (my car overheated alot and there was no coolant and spots on floor) and had to replace it.
BoloYang6 is offline   Reply With Quote
Old 02-22-2020, 10:43 PM   #8
airheads
Drives: 2011 SS/RS Synergy Green Camaro
https://www.camaro5.com/forums/showt...t=Coolant+leak
I had the same leak. Be careful, my closest dealer was quoting me $1100.00 to replace the fitting. They were saying they had to remove suspension parts to access it etc. That's when I researched the problem on here and did it myself. It's not hard if you have the right socket and extensions.
airheads is offline   Reply With Quote
Old 02-23-2020, 06:24 AM   #9
Suzies SS
Suzies SS's Avatar
Have the tools, good work space, However, i'm 73 now an just dont feel like working any more. ( except on my boat )
Old 02-23-2020, 07:31 AM   #10
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I hear ya there, Im 63 and sometimes just don't want to do the work myself. Like I said before, only took about 30-45 minutes but they charge an hours labor, so shouldn't be too bad, cost me about 150.
Old 02-24-2020, 07:19 AM   #11
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
I had the same thing. The engine oil cooler line was cross threaded from the factory. Unfortunately for me I had to replace the entire block.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs
rberns is offline   Reply With Quote
Old 02-24-2020, 12:15 PM   #12
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Wow, well that sucks, I got luck and they didn't even have to use the tap to clean out the thread, and it wasn't seized up in the block like some folks had..
Old 02-24-2020, 12:28 PM   #13
LsxDoctor
15 Year LS1Tech Member
LsxDoctor's Avatar
Drives: 2010 ss 391ci LS3
Save the headache and delete that oil heater. Frees up quite a bit of room too!
GJDM
LsxDoctor is offline   Reply With Quote
