07-15-2014, 12:59 PM | #1 |
Drives: 2012 IOM 2SS/RS Join Date: Jan 2012
3.91 gear swap on my L99
I am wanting to do 1LE gear swap to my L99 but I am concerned about my warranty. Will doing the gear swap void my warranty? Do I need to have my dealership do the install?
07-15-2014, 02:11 PM | #2 |
BC 2010
Drives: 2010 Camaro SIM 2SS/RS M6 GFX SR Join Date: Aug 2009
No and No
07-15-2014, 02:14 PM | #3 |
Drives: 2016 2 SS Join Date: Jun 2014
I am having the dealership do mine as we speak they are a little high cost wise also.
07-15-2014, 02:15 PM | #4 |
So if I got another shop to do my gear swap then my car is still under warranty? What do I do if the dealer ship tried to void it for some reason?
07-15-2014, 02:22 PM | #5 |
I'll be back...
Drives: Subaru, HD Road Glide Special Join Date: Apr 2012
The ECM (engine computer) needs to be reprogrammed to get your speedometer to read the correct MPH with the gear swap. Any reprogramming that is done outside of a GM dealer can and will put your warranty at risk. In the event of a major powertrain component failure, the dealer is required to send in a snapshot of the ECM calibration, and if it isn't a GM calibration, they will deny the claim and void your powertrain warranty. No exceptions.
Bye bye, Bumblebee!
07-15-2014, 02:52 PM | #6 | |
What's this button do?
Drives: 2019 Black 2SS Join Date: Apr 2013
2019 Black & Red & Silver 2SS - Bone Stock
07-15-2014, 02:56 PM | #7 |
Ok so if I did the gear swap at another shop but did the speedo recalibration at the dealer then it is still under warranty, got it.
What if I reprogrammed it myself with my own programmer and if for some reason there is power train failure I returned it to the stock tune. Would they be able to tell or void? Sent from my iPhone using Tapatalk |
07-16-2014, 02:36 PM | #8 | |
I'll be back...
Bye bye, Bumblebee!
07-19-2014, 05:39 AM | #9 |
Drives: 2013 SS Supercharged Convertible Join Date: May 2013
07-22-2014, 02:04 AM | #10 |
Drives: 2011 Camaro ss Join Date: Apr 2014
Your warranty will not be voided if you buy the GM gears.. You can't buy another brand like richmond or yukon... It has to be GM.... and yes GM make the 3.91.. Not the 3.73 though...
07-22-2014, 07:09 AM | #11 |
"Black Ace"
Drives: Supercharged 2010 SS, 2016 Golf R Join Date: Aug 2008
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq |
07-22-2014, 09:04 AM | #12 |
Writer
Drives: 2010 SS / 1967 Camaro Join Date: May 2009
GM was coming out with tunes for folks doing a 3.91 gear swap, one tune for L99 and one for LS3. You'd need to find a dealer who installs gears. Most likely the dealer will be pricier.
True install time is 4 hours give or take. My 3.91s only took one attempt to set up and are totally quiet.
PROJECT HEAVY CHEVY
Camaro Now: Mods for the Masses Part I | Part II 13.15@106 1.95 | 100% Stock 12.37@112 1.85 | + Kooks Headers/Cats + 20" 555R + CAI + BW TB + UDP + Tune 12.06@113 1.70 | + CD 3200 + 18" NT05R + RCR Intake + NE OTR + GPI Tune 11.84@115 1.59 | + 3.91s + Race Star 17x7 Fronts 10.90@125 1.47 | + GPI VVT Cam + BW Ported Heads + CD 3800 |
07-22-2014, 08:12 PM | #13 |
07-22-2014, 09:59 PM | #14 |
Ok so I am getting two different stories:
1. The dealership has to install the gears for me to be covered under warranty 2. The dealership does not have to install gears for me to be under warranty Not to be rude to anyone, but can someone with actual knowledge on this subject give me a straight answer on this. Because I am planning on doing this mod in the next week and I don't want to speed the extra money if I do not need to. Thanks |
