04-25-2017, 07:29 PM | #1 |
Drives: 18 ZL1 A10 Join Date: Nov 2008
ZL1 Lug Nut Torque 110 or 140?
Manual says 140, seems high to me. SS guys are saying they have addendums that say 110. Anyone know for sure? My wheel studs are NOT blue.. -Bobby
ZL1::J-E-T-S JETS JETS JETS |
04-25-2017, 07:34 PM | #2 |
KaBoom1701
Drives: 13' ZL1 Red M6 Join Date: Dec 2012
I've done 110lbs and never had a problem.
Several track days events under my belt as well.... 6th Gen might be different though...
Mods:
Roto-Fab Intake, WW Res. kit & Big Gulp Air Scoop, Elite Catch Can, ATI Super Damper & 18% OD Pulley, LF Idler pulley bracket, Metco CC breather, ID850 Injectors, Stainless Power Headers w/ ceramic coating, TR71X Spark Plugs, JMS Fuel Pump Booster, Bo White TB, Tuned by Ted @ Jannetty Racing, Ron Davis HX, D3 Reservoir, Pfadt 1" Springs, Moreno Camber Plates, ZL1 Addons Splitter guard washers, Tow Hook kit & rock guards, Hurst Shifter Billet Plus 6 Speed Short Shifter, ZL1 DRL lighting harness, ZL1 Recaro Seats. |
04-25-2017, 07:47 PM | #3 |
Ya, the 5th gen has the blue studs....that's 110 for sure
04-25-2017, 07:58 PM | #4 |
Drives: 16 Red Hot 2SS Join Date: Oct 2016
140 for the SS
'16 Red Hot 2SS A8 sunroof
04-25-2017, 09:51 PM | #6 |
These cars have 14x1.50 studs and should be 140. I torque mine at 135-140 for street wheels and drag pack setup. I would not do 110, but that's up to you. If they were 12x1.50 they would be 100-110 lbs of torque. I think I'd stick with what the manual says no matter if you think its to high or not. There is a reason why GM thinks that's the correct torque.
04-25-2017, 09:56 PM | #7 |
Drives: 2016 Corvette Z06, 2018 ATS-V Join Date: Dec 2013
I would not want to try and undo those nuts on a rainy night on the side of the expressway trying to change a flat with the jack from the trunk.
Get a Gorilla expandable lug nut wrench to put in the car at least. But yes, they are 140 ftlbs.
Perry
16 SharkGrey A8 Corvette Z06 18 Cadillac A8 ATS-V |
04-26-2017, 04:36 PM | #8 |
Drives: 2017 ZL1 Join Date: Dec 2009
Dammm 140 ft lbs is alot
Elite Design Concepts NY5THGEN2017 ZL1 Garnet Red/M6/// IG @Crazl1
04-26-2017, 07:29 PM | #9 |
Everyone needs a torque wrench
04-26-2017, 07:49 PM | #10 | |
Drives: 2019 Silverado Z71 6.2L A10 Join Date: Mar 2017
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's. Past Rides 2017 M6 Camaro ZL1 Hyper Blue 2016 M6 GT350 White with blue strips 2014 M6 Mustang GT Premium Track Pack Ruby Red 2012 M6 M3 Melbourne Red Metallic |
04-26-2017, 08:06 PM | #11 |
Drives: 2017 ZL1 Join Date: Aug 2016
Gen 6 Zl1 forum. Even if gen 6 ss or gen5 zl1 has same torque specs or not. We don't need to fish through unrelated stuff. Just saying. My OCD with forum organization is getting to me. Sorry.
04-26-2017, 09:12 PM | #12 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
04-26-2017, 09:28 PM | #13 |
Drives: 2017 V6 1LE Summit White Join Date: Feb 2017
I purchased a Lowes Kobalt 1/2-in Drive Click 50-ft-lbs to 250-ft-lbs Torque Wrench a few weeks ago. It comes with a hard plastic case to store it. It was on sale for 59.99, but is currently 79.97. It seemed like a very nice quality tool.
04-26-2017, 09:44 PM | #14 |
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6 Join Date: Sep 2013
It is 140 ft lbs for the 6th Gen ZL1. Sadly, even the service dept at the dealer doesn't torque them. After getting my 2nd set of rear tires put on I asked if the mechanic torqued them and they said no. Rather than bring it back in and wait, I took in to the self-help garage on-base and torqued them myself. Found that most were under-torqued and 3 were over-torqued.
If you drive your car fast, this is a safety issue. Even if you don't, uneven torque can cause the rotors to warp when they heat up. This can lead to brake failure when you need them most. Hand-tighten first, then snug them all up. Then torque each one just until you hear the click, skipping one lug each time, until there's no more movement. --Cal |
