Old 05-30-2019, 04:21 PM   #1
gtholmes
Drives: 2016 Chevrolet Camaro 1SS
Premium Gas?
I have a '16 SS. Do you guys bother with premium gas?
gtholmes is offline   Reply With Quote
Old 05-30-2019, 04:23 PM   #2
srcstc
I only use premium but if you want to use regular go ahead. It's your car.
srcstc is offline   Reply With Quote
Old 05-30-2019, 04:23 PM   #3
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
close this thread.
do a search.
you'll find literally a hundred identical threads already.
absolutely nothing productive or informative will come out of this thread. Just a repeat of the same argument for it, and the same arguments against it. Nobody will be convinced they're wrong, nobody will be convinced both sides are right.
Old 05-30-2019, 05:25 PM   #4
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Yes, you must use at least 91. 93 is recommended.
Old 05-30-2019, 05:40 PM   #5
Allez
Allez's Avatar
Bothered to pay a lot of the money for the car, so figured I'd bother to follow the recommendations of the manufacturer.
Allez is offline   Reply With Quote
Old 05-30-2019, 07:08 PM   #6
Move'n Up
Move'n Up's Avatar
Drives: 17 Z06/Z07, 17 2SS Fifty, Ram 2500
If you can't afford to feed it Premium fuel then you purchased more car than you can afford to operate. The LT1 needs 93 octane in order to deliver the 455 HP & 455 TRQ. Anything less and you're not going to get that out of it.
Build Date 8/1/2016 1,109 out of 5,982| Club F1FTY
Move'n Up is offline   Reply With Quote
Old 05-30-2019, 07:13 PM   #7
Aragorn
Drives: Camaro SS 1LE
Is 93 readily available? I haven’t seen any in Phoenix.
Aragorn is offline   Reply With Quote
Old 05-30-2019, 07:33 PM   #8
KSA464
Drives: 2018 2SS
Not only do a search on this topic, but also read the owners manual; "93 octane RECOMMEND" not ONLY or SHALL or MUST.... It's only recommended -but I would be in the camp that you should. As said here, the full performance numbers will not be achived with anything less. But I too cant find anything over 91 here either.
KSA464 is offline   Reply With Quote
Old 05-30-2019, 07:48 PM   #9
Aragorn
Phoenix, but not sure if any of this would work for our cars...
http://www.azmustangs.com/racegas.htm
Old 05-30-2019, 08:18 PM   #10
SSJ455
SSJ455's Avatar
Drives: "Kara Zor-El" 2017 2SS HBM
Yep
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!!
What?
Dangerzoooooone.
SSJ455 is offline   Reply With Quote
Old 05-30-2019, 11:07 PM   #11
Brudda*Termite
Brudda*Termite's Avatar
Drives: 2017 Camaro 2SS
At high altitude, I think 91 is the equivalent of 93, at least what I remember living in New Mexico back in the day at 6000 feet...
Gary
2017 2SS A8 White, Bolt-Ons, Prayed Upon
Brudda*Termite is offline   Reply With Quote
Old 05-30-2019, 11:29 PM   #12
V8RWD
V8RWD's Avatar
Drives: 2017 Camaro SS 50th
lol never heard of octane going up with altitude before
V8RWD is offline   Reply With Quote
Old 05-31-2019, 01:50 AM   #13
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
Higher elevation requires less octane because thinner air tends to prevent detonation. Because of this, a car that would normally need 93, can use 91 and obtain the same results.
If you go to Denver Colorado, you won't find 87 Octane, you'll find 85 instead for example.
Need4Camaro is offline   Reply With Quote
Old 05-31-2019, 02:10 AM   #14
TEST DRyVer
TEST DRyVer's Avatar
Drives: 17 ZL1 6mt with PDR
You are tha man! Thanks for that! The only place I've been able to find and use is Tom's Thumb (which ironically has some of the best "wet" brisket money can buy! You heard that right, a "gas station" has brisket better than many excellent bbq places, including the South). Anyway, I used to fill up (once a month) 95 octane for my heavily modded Mk 6 Golf R there. The only other place i know of is by Wild Horse Pass.
As far as the OP, there's no such thing as a stupid question, except for yours sorry...
Current Daily: 2017 ZL1 6mt in Black with PDR.
Esthetics: Nardo Grey wrap with original black accents throughout, complete Xpel ceramic coat, Diode Dynamics markers, Smoked GM tail & 3rd brake light, C7 Carbon 1LE style Spoiler in blk, ACS splash guards, blk'd out emblems. Variant Krypton wheels in Gloss black.
Performance: AWE Touring catback exhaust with resonator, Rotofab dry intake, TM throttle body, Kooks 1 7/8 Headers with Green Cats, Advanced Fuel Dynamics Flex Fuel kit with e50 blend and dyno tuned.
Current Family car (for the wifey): 2021 Audi SQ5
TEST DRyVer is offline   Reply With Quote
