12-30-2015, 06:25 PM | #1 |
Drives: 2022 Satin Steel ZL1 M6 Join Date: Sep 2015
"Idle hours" on DIC???
So I know what idle means. But I can't figure out what the car counts as idle time. If it is accurate it goes up 1/10 of an hour every 6 minutes. But when does it start counting "idle time?" If I am stopped at a red light for 45-90 seconds does that add to the cumulative idle time? Does it start after the running vehicle has not moved for "X" amount of time? I am curious because my cars ratio of "engine hours/idle hours" seems really high on the "idle" side. I have not spent nearly half my hours idling. Someone enlighten me please
12-30-2015, 06:29 PM | #2 |
The BEAST
Drives: '16 2SS, '89 Wife Join Date: May 2015
my guess is any time spent not adding miles is idle time. so yes, red lights and stop signs im thinking are counted as idle time.
Edit: did you see what the idle time was when you first got the car? some of it might be from QC or the dealer getting some revs in? |
12-30-2015, 06:57 PM | #3 | |
12-30-2015, 07:30 PM | #4 |
Camaro Fan
Mine were 10 engine and 6 idle from the factory
Ordered: Garnet Red Tint coat 2016 Chevrolet Camaro 1SS, Auto, NPP
1100 Status: 8/6/15 3800 Status: 10/13/15 VIN #116519 4200 Status: 12/19/15 Delivered : 12/28/15 |
12-30-2015, 07:48 PM | #5 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
Maybe idle hours is not under load? Like highway cruising in top gear, braking, stop signs, red lights?
12-30-2015, 09:59 PM | #6 |
Drives: 2016 Garnet Red Camaro 2SS Join Date: Jul 2015
I didn't even see this...I need to check that out, thought I saw everything, guess not!
12-30-2015, 10:13 PM | #7 |
Drives: 2010 2SS ABM -Sold Join Date: Jun 2009
I had 4 hours on mine when it arrived
2016 Hyper Blue 2SS M6 White Interior Mag Ride NPP GFX
12-30-2015, 10:15 PM | #8 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
I tried to Google this briefly and it seems to be an enigma how the manufacturers get this calculation.
12-31-2015, 07:15 AM | #9 |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
I imagine that it is simply hours with the engine RPM set at idle speed. Basically 0% throttle input in park or neutral. I suppose that could include a manual trans car coasting in neutral, but I doubt it. Probably has to register 0% throttle and no wheel speed input.
MJK3888 Instagram Link
12-31-2015, 09:30 AM | #10 |
Drives: 16 Camaro, 11 Stryker, 00 Explorer Join Date: Dec 2015
Without any knowledge on the subject, I would guess that idle time is the amount of time that the engine was running while the wheels are not. So that would include every red light, stop and go traffic situation, etc.
NGM, 2SS, 6MT, NPP, MRC, Nav, Kalahari, Grey Wheels
1100 12/14/2015 3000 1/8/2016 (TPW 2/1) 3800 2/1/2016 5000 3/5/2016 |
12-31-2015, 09:42 AM | #11 |
Drives: 2SS - Hyper Blue/Ceramic White Join Date: Dec 2015
First thing I'll check when I pick mine up.
2SS - Hyper Blue/Ceramic White, A8, MRC, Npp, Sunroof, Low-Gloss Black Wheels, White Rally Stripes.
12-31-2015, 12:33 PM | #12 |
EMERALD COAST CAMAROS
Drives: None Join Date: Feb 2010
Anyone check the owners manual to see if it says anything about this?
12-31-2015, 02:42 PM | #13 |
Drives: 2014 Maxima Join Date: Dec 2015
That's pretty cool you can see the engine hours. That's a neat feature to have if you upgrade anything and need the info for rebuild/maintenance purposes.
Sent from my iPhone using Tapatalk |
12-31-2015, 04:07 PM | #14 |
マスタング = 遅い
Just ask your salesman, I'm sure they will know.
