Old 06-22-2016, 10:16 PM   #29
bballr4567
Drives: 2016 Camaro 1LT M6
Was there any residue on the back bumper???
bballr4567 is offline   Reply With Quote
Old 06-23-2016, 05:41 AM   #30
sonnydurden
sonnydurden's Avatar
Drives: ‘16 1SS & ‘19 1LT
Naw, nothing at all.
sonnydurden is offline   Reply With Quote
Old 06-23-2016, 06:26 AM   #31
MiamiBlueCamaro
MiamiBlueCamaro's Avatar
Drives: Gen 6 Camaro RS
Originally Posted by sonnydurden View Post
Will do!!! But what can I do? I can only control what I can control. It stings really bad. Having a fit over it won't change anything. I learned about 10 years ago to try hard to never get upset over things you can't control!
+1
Old 06-23-2016, 07:46 AM   #32
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova
If any one wants to know, the 6.2 in the truck line are having rod bearing problems too, how many I don't know but it's happening.
2SSRS@Gen5diy is offline   Reply With Quote
Old 06-23-2016, 09:13 AM   #33
sonnydurden
Thanks Ofer!! Are they resolving it for you?
Old 06-23-2016, 10:52 AM   #34
2SSRS@Gen5diy
I have no problem with Engine on the 6th gen, this is info from my dialings with dealers, as for the blue car that's a long and legal mater, other then that all is good.
Old 06-23-2016, 11:57 AM   #35
Chevrolet Customer Svc
Chevrolet Customer Svc's Avatar
Drives: GM Vehicles
***Update***
I didn't hear back from the dealership until around 1:00PM today after I called Chevrolet Customer Service. Then all of a sudden every one from the GM to the Service Manager was blowing up my phone and a loaner Malibu magically appeared. Had a long talk with the service manager. All they know is the engine is locked up. They can't figure out where the oil went as there are no leaks, why no low oil light came on, and when you start it the oil pressure shows 40 psi. They said they have to break the engine down to see where it failed. And decide if they can fixed what is broken or give me a new engine. This is a true mystery
Hello sonnydurden,
We’re glad to hear you’re in good hands at the dealership, and that you were provided a courtesy vehicle, though we understand how upsetting your engine concern may be. If you would like us to take a closer look at your case, please feel free to send us a private message with your VIN or case number.
Steph B
Chevrolet Customer Care
Chevrolet Customer Svc is offline   Reply With Quote
Old 06-23-2016, 01:11 PM   #36
sonnydurden
Originally Posted by Chevrolet Customer Svc View Post
Hello sonnydurden,
Steph B
Thanks Steph!! Please see PM sent!
Old 06-27-2016, 08:11 AM   #37
sonnydurden
Dealer called this morning. Bad O-Rings caused the oil to burn up that cause the engine failure. But I wasn't experiencing any smoke out the back. The most concerning issue to the techs/engineers is the fact that the oil pressure gauge shows good and no low light was triggered. Even bone dry. They stated those sensors will be replaced as well. Just give me the old fashion 4 pack gauges. Don't trust this animated/digital sh*t!! Also, to be fair, the dealership had a bad phone number on me. That's why they weren't calling me back.
Old 06-27-2016, 08:29 AM   #38
bballr4567
D'oh!!!
There is no oil level light. There is just a low pressure warning.
Old 06-27-2016, 08:36 AM   #39
SpookShow'84
Bump in the night
SpookShow'84's Avatar
Drives: '84 Monte Carlo SS, '15 Optima
That is concerning. A simultaneous failure of three components without normal symptoms of a problem, without the ability to spot the problem before the engine self destructs. Let's hope your situation is an isolated event. Thanks for updating. Is it a software problem, or a sensor problem? Rings failing? I wonder how many cars have that same series of rings or if it was causes by a problem in the oiling system.
SpookShow'84 is offline   Reply With Quote
Old 06-27-2016, 09:04 AM   #40
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
This is part of the reason why I just ordered a bluetooth OBD2 plug-in and will be running Dash Commander. Hopefully it helps keep any eye on things so I can spot a problem before it materializes.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 06-27-2016, 01:08 PM   #41
sonnydurden
D'oh!!!
Right.. In any event the warning light didn't come on and the oil pressure shows 40 PSI..
Old 06-27-2016, 01:54 PM   #42
bballr4567
Technically you can still be low on oil and have good oil pressure. I think the bottom of the dipstick still means you have 5.5 qts of oil in the LT1.
