10-19-2023, 07:14 AM | #1 |
Drives: 13' 1LE Join Date: Apr 2012
Solid roller N/A SBE hit 605rwhp on the roller
Very happy about the setup and ultimately, having a real number after last dyno when the rpm signal was skewed and the run was cut around 7k and the numbers were still climbing but the run stopped (568rwhp). I upgraded the exhaust to a full 3'', X pipe and Z28 mufflers since then.
I finally hit the rollers and this time the rpm signal wasn't acting up like last time. MODS Solid roller N/A, Cam Motion low lash no fly cut 239/253 720' 702' T&D 1.8, Smith Brother custom pushrods (very short like 6.8ish), 1530 PAC springs, Isky rev extreme linked lifters stock SBE 50k miles, RPS twin, James Goertz custom fit manifold intake, 102mm TB, EWP, 2" SW LTs& HFC, 3" exhaust Xpipe into Z28 mufflers, forged 19" wheels, wildwood rear drag brakes, FED TFS custom heads, 11.33 CR, 91oct, Pat G Tuning remote tune with no wideband, Vararam VRX with green air filter, JRE scoop, short belt mod, Fluid damper, Zrod 10w30 oil. A full bottle of VP oct booster 1/4 tank of 91oct. Work done by me. Thanks to my crew for all help and advices: Tyler for the cam!! Phillip Green Doug Clark Zack Aaron Popp for the logistik haha And all other involved, especially my wallet who suffered a lot 605rwhp with the sae correction. 622rwhp uncorrected, air was good; 0.974 correction factor. I did 595 engine hot, then let it cool and removed the AC belt then did 605rwhp!
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. Last edited by WHAMMO; 11-08-2023 at 11:20 AM. |
10-19-2023, 11:10 AM | #2 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
Nice!
Sent from my Pixel 5 using Tapatalk
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
10-20-2023, 10:51 AM | #3 |
Holy cow man, that's awesome!! Well done sir!!
10-21-2023, 07:45 AM | #4 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Awesome to see outcome of builds
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
10-21-2023, 08:02 AM | #5 |
awesome!
2014 Camaro SS L99, Ashen Grey w/Black Leather - Build thread - http://www.camaro5.com/forums/showthread.php?t=491561
Mods - GPI 416 w/Custom Grind Cam, Ported Heads & Tuned by Ben, Holley Dominator ECU, Mag Heartbeat, ZL1 Fuel Pump & DSX Aux Pump, NW 103 TB, FIC 1650's, Alky Meth, Circle D 3600 Triple Disc, Kooks Headers, Viking Coil Overs & all the BMR Goodies in the rear, Zl1 3.23 Diff, DSS Axles, Gulfcoast Driveshaft, Hendrix Offset Diff Bushings, AFE Solid Subframe Bushings, 875HP/843TQ 5FDP |
10-24-2023, 02:24 PM | #6 |
Oh hell yeah!
I have a question though on that mammoth cam lift. Those cam lift numbers are NOT factoring in the 1.8 ratio rockers, right? Either way, that's insane and we need to hear this! I love these sick solid roller builds. Congrats!
10-29-2023, 10:23 AM | #7 |
They do factor the 1.8 Its around 690 lift cam if 1.7 ratio.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
10-29-2023, 08:56 PM | #8 |
Youtube video link
https://youtu.be/dp8DSv2HsD0?feature=sharedhttps://youtu.be/dp8DSv2HsD0?feature=shared
13' 1LE
10-30-2023, 06:30 AM | #9 | |
GPI Sales Consultant
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message! |
