06-04-2019, 04:16 PM | #1 |
Drives: 2016 Camaro 1SS Join Date: Mar 2019
Secondary Cat Delete (WILL I PASS SMOG?)
Hello guys,
Recently I did a SC Delete on my SS with the GM Performance Exhaust, and I absolutely love the sound. The car sounds the same while cruising, but if you gun it, it sounds awesome it crackles and pops even more! Now I did do my research, and from what i can tell you can pass smog as long as everything else is good, but some people disagree. I've been told by the guy that did my delete that plenty of guys have came and did the same exact thing and that CHEVY put the SC there to make sure their cars will pass SMOG. What do you guys think? |
06-04-2019, 05:09 PM | #2 |
Drives: 22' Porsche PDK GT4 Join Date: Mar 2018
There is a reason why Corsa and Borla will not sale their X-pipe in CA, as it removes the secondary cats. This will make it not pass CA smog.
The secondaries were added for it to pass CA smog. Luckily, I won't have to worry about it for 6 years, by that time I will be looking to upgrade and start over.
Current:
22' Porsche PDK GT4 (MCS 2-way remote dampers) Previous: 18' NFG 2SS 1LE (ZL1 1LE solid rear cradle bushings & Corsa Exhaust) 16' F80 M3 (Ohlin R/T Coilovers) 13' Audi TTRS (APR Stage 1, MSS Springs) 09' C6 Z06 08' E90 M3 06' 335i (KW V2 Coilovers) 03' C5 Z06 |
06-04-2019, 06:25 PM | #3 |
good thing is you dont have to smog by 6 or 7 years so you will be good until then lol just keep your oem parts or get a illegal smog
06-07-2019, 06:17 PM | #4 | |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
06-07-2019, 07:20 PM | #5 |
Drives: '18 5.7 RAM 1500 18' 1SS Join Date: Jun 2009
CA smog check in not required for 6 years on new cars.
Also, the smog check is a OBDII test. Basically, the inspection "scanner" plugs into your car and your car reports smog status. There is a visual component as well. Now, how in-depth the visual is depends on who is doing it. I have never seen any shop jack a car up and look for second cats. If they bother with the visual at all its usually a quick check for headers and no smoke coming from the tailpipe. If your rocking a power adder they might question it, maybe. The short story is, if your looking to delete the second cats I would not worry about CA BS smog crap at all.
JRE Tune
06-08-2019, 10:32 AM | #6 |
Drives: 2018 2SS Redline Join Date: Jan 2019
Depends if you want to roll the dice. And on how much of a stickler the tech at the emissions station is. Some do the minimum... probe in tail pipe, mirror in the wrong spot under the car... while some go all out, with the mirror under the car in different spots and some will crawl under there if they think something is up (ie a loud @$$ exhaust sound). I know people that have not passed and had to have their exhaust system removed or put back to stock to pass. If you have the time, $$$, and are willing to roll the dice... go for it.
06-08-2019, 11:47 AM | #7 |
Drives: 66 Chevelle SS Join Date: Mar 2013
In California they will fail you on the visual. Common sense says if it is clean out the tail pipe it should be good but CARB is by no stretch a sensible entity.
66 Chevelle SS 396
91 octane Driver n/a 6.44@105.78 1/8th mile |
06-08-2019, 03:08 PM | #8 |
Drives: . Join Date: Jan 2013
Won't pass visual. If the inspector sees anything modded, it's game over unless it has a CARB sticker.
06-08-2019, 07:50 PM | #9 |
Drives: 2018 SS, 2016 GT Join Date: Mar 2018
The question is, which smog places know about the secondary cats?
Do all 6.2 lt1 come with secondary cats? |
06-08-2019, 10:01 PM | #10 |
Every one of them with a Smog license.
66 Chevelle SS 396
06-09-2019, 05:18 PM | #11 | |
Also, what random tech knows where the second cats are and will jack the car to get to them. I don't think you can see them with any mirror. Its to low. Last smog ch I did (March 2019/2006 ford Escape) was over in 10 mins. And that included paying....
JRE Tune
06-10-2019, 09:19 AM | #12 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
smog checks are like tinting your windshield or not driving with a front license plate. It's rolling the dice until you get caught.
removing the secondary cats is against federal law, so any state inspection regardless of being part of CARB or not should fail you. Most dont go all anal with visual inspections though so you skirt by if the computer says everything is going great. Self inspection is such a stupid thing. No legitimate test is going to go by the honor system to grade you. Bring back the tailpipe test, then get rid of any sort limits to what you can put on the car or take off as long as the sniffer says you're in the green according to stock standards over the course of the dyno test. |
06-11-2019, 02:08 AM | #13 | |
all it takes is cash
Drives: 2018 LS V6 1LE; E350 wagon; Model3 Join Date: Jan 2017
OBD2 testing + visual inspection is unliikely to go away. Without it, people will do things like advance timing, remove EGR equipment and secondary cats, thereby degrading emissions performance. Keep in mind, before OBD2 testing, it was tailpipe testing + visual inspection. It's still the protocol for older gas cars in California. |
06-11-2019, 12:22 PM | #14 |
Drives: 2019 1SS 1LE Join Date: Mar 2016
Are you saying this from experience?
19 1SS 1LE - Suntek PPF - Corsa Xtreme Axle Back
