dave@hennessey
Old 09-16-2016, 03:16 PM   #1
eddy94
Drives: Black 2LT W/ Rs
Weird spot after polishing
Hello guys, so today i finally decided to fix a scratch that i had. I tried wet sanding with 1500 grit and worked my way up to 3000 to get most of the scratch out, but the scratch was way too deep probably down to the primer so i stopped sanding and just started polishing. When i finished i saw this weird spot and after trying to polishing out, it still wouldn't come out.
Do ya have any suggestions on what i can do?
LED fog lights, 35% tint all around, 20x10 front 20x11 back, ZL1 Replica wheels, Light Smoke Tint all tailight and side markers
Performance Mods. CAI cold air intake, Catch Can,
mrt v2 exhaust
eddy94 is offline   Reply With Quote
Old 09-16-2016, 03:47 PM   #2
Gary24
Drives: 2014 Camaro 1SS 1LE
I don't see it. Top pic is blurred bottom I don't see anything but a yard and fence, sideways.
Gary24 is offline   Reply With Quote
Old 09-16-2016, 03:53 PM   #3
jrhagen
Drives: Camaro
Looks like a fuzzy spot.
jrhagen is offline   Reply With Quote
Old 09-16-2016, 04:15 PM   #4
Cyber10
Cyber10's Avatar
Drives: 2010 Camaro 2SS/RS
Hard to tell from those pics but my guess is either you didn't polish the sand scratches out all the way so there is still a haze, or you burnt through the clear. Hard to say exactly what it is though unless you can get better pictures of that spot.
491 hp/438 tq
LS3 Conversion | Comp Cam Custom Grind | Mast Heads | Comp Cam Push Rods | LS7 Timing Chain | 180 Thermostat | Ported Intake | Ported TB | SLP UDP | K & N CAI | Custom 3800 Stall Converter | Aluminum 1 Piece Driveshaft | Kooks 1 7/8" LTH | High Flow Cats | ARH 3" Exhaust | ARH Mufflers | Eibach Lowering Springs | BMR Floor Brace Subframe Connectors with Tunnel Brace | BMR Moly Lower Rear Control Arms | Oracle LED Halo Kit
Cyber10 is offline   Reply With Quote
Old 09-16-2016, 08:08 PM   #5
eddy94
I'll try to post a clearer picture, it's just that the spot is very small and when I get close to take a picture of it, it becomes very distorted.
mrt v2 exhaust
Old 09-16-2016, 08:19 PM   #6
eddy94
here's the photo that fuzzy spot
mrt v2 exhaust
Old 09-16-2016, 10:37 PM   #7
SlowSS
SlowSS's Avatar
Drives: 2013 Camaro 2SS/RS 1LE
Judging by that last pic, I'm going with damage to the clear coat. And you are probably not going to do anything with that sractch. Looks like it's through the paint as well.
SlowSS is offline   Reply With Quote
Old 09-17-2016, 01:31 AM   #8
scandata
scandata's Avatar
Drives: 2015 2SS/RS vert, Spring Green Edtn
If it were me, I'd try using Dr. Colorchip (or similar).
2015 2SS/RS vert, Spring Edition Green Flash (2015 - present)
2014 1LT vert, Blue Ray Metallic (2014 - 2015)
http://img.photobucket.com/albums/v692/scandata/sigpic_zpsxmxmbipg.jpg
scandata is offline   Reply With Quote
Old 09-17-2016, 08:21 AM   #9
eddy94
Is there any way to fix the clear coat? And I have the lanka system so I'll try that out just to fill in the scratch.
mrt v2 exhaust
Old 09-17-2016, 04:17 PM   #10
scandata
scandata's Avatar
When I used Dr. Colorchip, it seems to have the clearcoat mixed in. After using it, I couldn't even tell where the scratch was - the gloss blended in perfectly with the neighboring areas
Old 09-17-2016, 10:25 PM   #11
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
Send a message via AIM to nUcLeArEnVoY
Look to me like you went through the clearcoat, man. And if that's the case, then the UV protection offered by the clearcoat in that area has been compromised and that damage will begin to spread. The panel will need to be repainted. On the bright side, that will also take care of the scratch.
Looks like it also might be dried on polish residue that has been baked onto the finish. Try wetying it with some QD and then hit it with the polisher again at medium speed.
nUcLeArEnVoY is offline   Reply With Quote
Old 09-18-2016, 07:47 AM   #12
eddy94
Thank you so much for your input, I'll ask around to get a quote because now I'm noticing chips all over my rear quarter panel lol.
mrt v2 exhaust
Old 09-18-2016, 11:34 AM   #13
chef-beavis
chef-beavis's Avatar
Drives: IOM 2013 2SS/RS, Greenie, 06 FXSTBi
Yup. Through the clear and have polish embedded in the scratch. Paint time for the burn, through. Sorry OP.
chef-beavis is offline   Reply With Quote
Old 09-18-2016, 01:00 PM   #14
Cyber10
Cyber10's Avatar
Agree with this based on the past pic, if it were caked on polish/compound you'd be able to wipe it off with a little pressure on a microfiber. If it doesn't wipe off though then you started to burn through the clear which will need repainting.
On the bright side like someone else said, when you get it repainted they will be able to repair the scratch at the same time so it will at least end up fixed, it'll just cost you a little more.
491 hp/438 tq
