09-29-2011, 12:19 AM | #1 |
Drives: Camaro <3 Join Date: Sep 2011
So if I understand correctly about the SS..
Hey guys 1 final question before im ready to order . The SS... it needs a higher octane so i have to go with the more expensive gas? The 87 octane or the 93? It would say in the owners manual I know but I wanted to know so im prepared.. Is the SS really worth it or should I just go with the 2LT? Also what kind of oil...?
Thanks alot guys |
09-29-2011, 12:21 AM | #2 |
Camaro➎ moderator
The SS, needs 91 or higher octane and synthetic oil.
09-29-2011, 12:21 AM | #3 |
brevard
Drives: 2012 Black 2SS/RS M6. Join Date: Jul 2011
in the owners manual it says 87 is OK, but it will run better on 91 or 93. it also says do not put anything below 87 in the tank or it will hurt your engine. I put 93 in mine.
09-29-2011, 12:45 AM | #4 |
Wonderfully Awful Idea
I use 92 OCT. I also get 27.5 at 70 mph cruse control on.
09-29-2011, 12:46 AM | #5 |
Drives: 2011 1SS/RS LS3 Join Date: May 2011
It gets better mileage and runs smoother with 91+. I have ran both. It's worth the coin.
We don't have 93 here (altitude) so I can only get 90/91. If you run the lower octane, the higher octane won't matter unless you reset the fuel map with a fuse pull. Simple to do, and it works.
09-29-2011, 12:50 AM | #6 |
ace5.org
Quick question....is the engine "tuned" from GM to get the most performance on 91?
I know 93 is better...but if 91 is all you have are you getting the full potential of the engine?
Stock...For Now.
09-29-2011, 12:51 AM | #7 |
Camaro➎ moderator
yup.
09-29-2011, 12:53 AM | #8 |
I did some research after hearing about the 93 octane being the best. If you are at or close to sea level, 93 is supposed to be equivalent to 91 at higher elevations. I am at 6400 ft, so less dense air with lower octane has the same effect. I just put in the highest octane available and smash the right pedal.
09-29-2011, 12:58 AM | #9 |
ace5.org
Stock...For Now.
09-29-2011, 01:27 AM | #10 |
Drives: 1SS Black w/ White Strips M6 Join Date: Feb 2011
Yes the SS is worth it.
09-29-2011, 01:48 AM | #11 |
SS is absolutely worth it. I know I'd be kicking myself if I got he LT (no offense LT drivers). The power is what sold me. Have you test-driven either yet?
09-29-2011, 03:24 AM | #12 | |
The thin blue line
Drives: 2012, 2SS/RS,LS3,IOM/Beige Join Date: Aug 2011
09-29-2011, 03:47 AM | #13 | |
Sold car...
Drives: 2010 Rally Yellow 2SS/RS #37115 Join Date: Oct 2009
Build Thread
ECS Novi 1500 Supercharged, LS3 conversion, Small blower cam, Alky Meth injection, 3:45 rear, BMR Suspension parts, 1LE Sways, Billy Boat ZL1 dual mode exhaust. |
09-29-2011, 07:54 AM | #14 |
Like others have said you will need to use premium fuel and synthetic oil(8 quarts). However, I would be putting synthetic in a V6 also. The SS is worth every penny.
I think your biggest decision will be what transmission to get. Put A LOT of thought into this. Read the threads. There are a lot of complaints about the A6 AFM and some people complain about having to install the skip shift elim in the M6.
20% Tint - Color match Bowties - Pypes Pype Bomb Axle Back System - Apex Skip Shift Eliminator - GM OEM Splash Guards
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
SS hood for sale and much more! | 2010_5thgen | Exterior Parts & Accessories | 2 | 04-22-2011 11:53 AM |
SS: 1SS and 2SS | The_Blur | 5th Gen Camaro SS LS LT General Discussions | 86 | 03-11-2010 11:12 PM |
Review of my Camaro SS (Rental from Avis) | clan0013 | 5th Gen Camaro SS LS LT General Discussions | 19 | 02-15-2010 05:10 PM |
Camaro SS manual shipment (not production) hold officially confirmed by GM (UPDATED) | Tran | 5th Gen Camaro SS LS LT General Discussions | 715 | 07-23-2009 11:05 PM |
camaro ss or 06 vette? | Robin | 5th Gen Camaro SS LS LT General Discussions | 45 | 08-23-2008 05:10 PM |
