01-17-2018, 01:21 PM | #1 |
High Pitch Whine
Anyone else have a 2018 2SS 1LE and have a high pitch whine noise in the interior when travelling any faster than 30mph. I can't find the issue for the life of me, I usually have the music up, so I don't hear it, but when its not, its annoying.
01-17-2018, 04:14 PM | #2 |
Drives: 2017 Arctic Blue 1SS 1LE Join Date: Mar 2017
I do not have this noise but if you have PDR you could use it to record the noise. At the least it will help you if you need to take the car back to have the dealer check it out.
01-17-2018, 04:23 PM | #3 |
I have the same issue on my 2013 and it is coming from the AC compressor. Turn it off and it is gone. I have had the issue for a while now and my AC still works fine. You may have a different issue.
01-19-2018, 06:54 PM | #4 |
I hear intermittently it out the back only when I am on the interstate going over 65 on new pavement , not a constant whine . I think it is the tires in my case.
01-20-2018, 08:27 AM | #5 |
Might want to check to make sure it isn't the rear diff. A lot of post on here about changing the rear diff fluid early because of whining coming from back. I did mine at 1,500. That might remedy your problem, read up on it. Goodluck
01-21-2018, 10:40 AM | #6 |
Drives: 2017 1LE Join Date: Nov 2017
Good point on diff. Had mine done with first oil change and they didn't charge aside from fluid. Should have brought my own fluid with me...perhaps next time
