05-21-2017, 03:39 PM | #1 |
Booooosted.
Coolant Temp Sensor help...
Been asked a few times on the site but each time seemed to be a bit different of a solution.
So I'll ask in a new thread. I am getting the 'AC Off Due To High Engine Temp' message. Been going on intermitantly for a while now. Well it's permanent now. I can reset the ECU but it will come back after a few miles. I swapped sensors and put a new connector on it. Wires look good. I have tested the sensors (both old and new) and tested power and continuance to the connector. Changed the thermostat with a new one and tested the old one and found it was good anyway. New coolant of course. Dash temp gauge turns off when the issue comes on. So I'm at a total loss. The code comes on immediately upon starting a cold engine or hot engine. Unless I unplug the computer and plug it back in. Then, like I said, I'll get a few miles before it comes back on. Codes are P0116 and P0118. I get a P219A but I suspect it's a result of the hard start and low efficiency brought on by the temp issue. Interesting note, the dash temp gauge shows just a tad warm when I start it after a reset. Weird. |
05-21-2017, 04:07 PM | #2 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
This curcuit may share info in the computer to another curcuit. Didnt you wreck the car a while back. You may have a pinched harness.
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
05-21-2017, 05:01 PM | #3 |
Booooosted.
The continuance test shows a full circuit. The electrical diagram shows no sharing on that circuit either.
But if so, how would I chase that down? |
05-21-2017, 08:13 PM | #4 |
Have you had a Tech 2 or MDI used on the car?
06-07-2017, 04:57 PM | #5 |
Booooosted.
Don't know what those are. I have tested every component.
06-07-2017, 05:38 PM | #6 |
Drives: 2010 1SS Join Date: Aug 2015
Just for laughs try leaving the old sensor out & connected to it doesn't get as hot and see if it still does it.. Meaning eliminate a real engine hot possibility.. If it still does it then it has to be an electrical issue and time to get busy there. Fans on when it does this I assume?
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
