Old 10-27-2013, 03:08 AM   #15
Rock36
I just like V8s
Rock36's Avatar
Drives: 2007 Corvette Z06
Originally Posted by Juiced1 View Post
There have been plenty of bone stock LS3 Vettes hitting high 11s so this doesn't surprise me much (ideal temps and track). The next gen Camaro with the same engine should be pretty fast. If they end up on the ATS platform and can keep the weight under 3500 it should be in the mid 12s all day with some guys diving into the low 12s and I'm sure there will be a freak or two to pop off an 11.99.
The 2002-2004 C5 Z06 also could run 11s in the hands of a skilled driver and some good DA.
Not too many drivers can pull 1.7 60' on a bone stock car like the guy with the C7 did. That is is definitely some good driving.
"Anyone know who sells the driver mods?"
2007 Corvette Z06: Le Mans blue, 2LZ
Rock36 is offline   Reply With Quote
Old 10-28-2013, 07:02 AM   #16
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
The new 6th gen needs to pull at least high 11's hero runs and mid 12's as average runs to be a success IMO. You have to hope it will gain 30HP and be at least 200lbs lighter so it better be a half second quicker. I really think the car will get smoked by the Mustang in a straight line if its not running high 11's for perfect conditions to mid 12's for average conditions. Even high 11's may not get the job done if the Mustang loses 200lbs and gains 30HP.
BLK/BLK 1SS/RS Ordered 11-01-2009 Took delivery 12-22-2009. Heads/cam/converter/bolt ons. SOLD Feb 2015 to fund 6th gen LT1 SS with 8L90E.
VADER SS L99 is offline   Reply With Quote
Old 10-28-2013, 08:05 AM   #17
Cody6.2
Drives: 2012 Camaro 2SS
Some of you are trying to figure out way too much with so little actual input.
Use the LS3 Corvette vs LS3 Camaro vs LS3 G8 GXP for example. Compare what the 3300lb Corvette runs vs the 3800lb Camaro as it's almost a complete second difference. But then compare the Camaro to the G8 and it skews the entire "what it should run" ideal.
In short even if the LT1 has no horsepower difference C7 to Camaro 6 it can still be nutted with a lame tune or loads of TM/TR. Therefore you can't even guesstimate as it's impossible to factor in an unknown variable.
Cody6.2 is offline   Reply With Quote
Old 10-28-2013, 08:36 PM   #18
VADER SS L99
Not sure what you mean because a narrow body LS3 Vette is 3250lbs with 436HP vs a 5th gen LS3 at 3850lbs and 426HP. Its more like a .7 second and 7mph difference so the math works out pretty good.
Old 10-28-2013, 10:58 PM   #19
Smirnoff
Smirnoff's Avatar
Drives: Camaro SS
Originally Posted by NASTY99Z28 View Post
So after seeing a bone stock auto c7 run 11.6's at 3400+lbs without driver what do you think the next camaro will run if it gets the same engine? Low 12's mid to high 12's being the norm?
Doesn't take a rocket scientist to get into the 11's.......
11.90's w/headers, CAI, custom tune, slicks/skinnys, shifter & 100+ Ethyl.
Smirnoff is offline   Reply With Quote
Old 10-29-2013, 09:01 AM   #20
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
yeah...I've seen quite a few stock or stock plus DR's c7s posting mid to high 11s now.
-John S.
grocerygetter is offline   Reply With Quote
Old 10-29-2013, 09:17 AM   #21
midnighter
Drives: nothing
12.5s
midnighter is offline   Reply With Quote
Old 10-29-2013, 10:18 AM   #22
sasquash1984
502 RWHP N/A
sasquash1984's Avatar
Drives: The yeti
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
sasquash1984 is offline   Reply With Quote
Old 10-29-2013, 12:08 PM   #23
ULTRAZLS1
ULTRAZLS1's Avatar
The vette guys are expecting mid to low 11 hero times out of the car in the future.
The DA was 500, the car could have had less gas in it, the driver was 230 lbs and the car will gain a bit of power with some more miles on it.
Old 10-29-2013, 12:17 PM   #24
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
Originally Posted by sasquash1984 View Post
That's crazy... Now I really want to sell my car and get a c7. So basically it looks like our 5th gens will need a blower to keep up with these c7's with a tune.
newagemuscle is offline   Reply With Quote
Old 10-29-2013, 12:42 PM   #25
KMPrenger
KMPrenger's Avatar
Damn...these things just keep impressing me more and more. 11.67 bone stock and now 11.4 with a tune. LT headers and tires and your looking at easy low 11s or high 10s.
The damn car is a Mustang GT500 eater with minimal mods. Amazing!
Old 10-29-2013, 03:03 PM   #26
sasquash1984
502 RWHP N/A
Drives: The yeti
Shoot get an auto c7 with cams, stall, tune, and drag tires mid 10's
Old 10-29-2013, 05:08 PM   #27
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
All depends on weight, of course.
If we're lucky, and the car on the Alpha platform - with a V8 - weighs only 3500-3600 lbs...it could be very very close!
I think a 3600 lb LT-1 powered Camaro is probable, if not likely....but I've got nothing concrete to prove that, besides educated guesses based on past engineering techniques...
They say...in that weight range...every 100 lbs is worth a tenth...
Should we talk about tires, too?
Old 11-21-2013, 10:22 AM   #28
Seer
Drives: 2015 Mustang GT
Originally Posted by KMPrenger View Post
I seriously doubt the Mustang is going to lose that much weight. The new car apparently rides on the same 107 wheelbase as the current car, but the changes in sheetmetal and what not make the smaller and probably help to shave some weight a long with advancements in the chassis. The independent suspension likely doesn't help in shaving weight either.
In the end, if the V8 Mustang weighs much under 3,400 if it even gets under that I'll be pretty impressed. It would have to weigh around 3,200 lbs if it lost 400 lbs.
New Mustang is riding on a new chassis. It will lose 350-400lbs, thats a given.
Seer is offline   Reply With Quote
