Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 06-27-2013, 09:48 AM   #1
Zl1vite
Drives: 2013 zl1 summit white
Roto-fab install -- grr, don't make this mistake
I failed to tighten the 90 degree elbow and it
loosened allowing the breather canister to rub against the belt.
Zl1vite is offline   Reply With Quote
Old 06-27-2013, 09:55 AM   #2
dmax86
dmax86's Avatar
Drives: 2016 Z06 C7R
no bueno
2013 ZL1 BONE STOCK! LOL
dmax86 is offline   Reply With Quote
Old 06-27-2013, 10:12 AM   #3
hawk02
Coupe Newbie
hawk02's Avatar
Drives: 2017 ZL1, 2021 Corvette Convertible
That's a bummer...
I wrote in another thread how I spent a good 45 min fiddling with the intake elbow and 90 degree fitting in order to make sure the breather canister was clear of the pulley belt. Surprised this issue was completely ignored in the written and video instructions.
Old 06-27-2013, 10:16 AM   #4
Zl1vite
I'm a bit concerned it sucked up plastic shavings.
When I would get off the gas to go to idle it would then rev up a couple times on its own.
Old 06-27-2013, 10:25 AM   #5
Hercules
Drives: 13 ZL1 1091, 04 Ram 2500, 12 CX9
That sucks big time! I'll have to recheck mine to make sure it's still not rubbing.
Thanks a lot
Hercules is offline   Reply With Quote
Old 06-27-2013, 10:30 AM   #6
avcbm
avcbm's Avatar
Drives: Camaro ZL1
What's that part number I need one
2012 Camaro ZL1
2010 Camaro SS (Sold)
avcbm is offline   Reply With Quote
Old 06-27-2013, 10:52 AM   #7
Zl1vite
Going to the dealer today at lunch to get a new one. I'll post the part number.
Old 06-27-2013, 01:06 PM   #8
Hercules
Just checked mine and mine is about 2" from the pulley. I think I know what happened to give you that problem. It sounds dumb but if You lined the elbow/"T" fitting up with the mark on the snout, that is probably why. When I installed mine I didn't like the fact that the valve, the one that you're replacing, wasn't centered in that 90 degree. So I just turned the fitting so that the vlve is centered. All you should have to do when you install the new one is turn the fitting towards the actual air filter and it should pull the valve away from that pulley. Mine doesn't sit perfectly straight, just a little tilted, but there is no way it should ever hit the pulley. Hope this helps and works for you guys.
Old 06-27-2013, 01:27 PM   #9
djnice
djnice's Avatar
Drives: 13 ZL1 SIM, 99 Z28 Black
Maybe reving up is normal with the new intake?
Shavings should just burn up. You could look in your throttle body with a flash light and see if there as any evidence of a problem at the supercharger. BTW, if you do that let me know what your supercharger rotor lobes look like. I am having an issue with the dealer on that right now regarding metal to metal wear.
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
djnice is offline   Reply With Quote
Old 06-27-2013, 01:46 PM   #10
hawk02
Coupe Newbie
hawk02's Avatar
That's exactly what I discovered during my 45 minutes of fiddling. I turned the 90 degree fitting towards the air filter as far as it would go. My canister doesn't sit straight either. To make it straight would put it right up against the belt.
Here's how much space I have between the cannister and belt. It's about an inch and 3/4 clearance.
Old 06-27-2013, 02:20 PM   #11
Zl1vite
Ok so the replacement part is $98.32 and is the hose assembly.
I'll post the part number, left in my truck.
They said 5 days to get it here so I may do a plastic weld instead.
I had tightened and aligned it to the hash mark. It was really tight but the 100 degree heat here had made it loose within 5 minutes.
I pulled the main elbow while hot and was able to screw in the 90 degree elbow like 3-4 more turns.
I'll take a picture thru the throttle body tonight so you can see the metal wear for previous poster.
Car has 1,100 miles.
Old 06-27-2013, 04:30 PM   #12
Hercules
I would have to say that the probable cause of it revving a couple of times is that when the pulley cut into the valve it then in turn created a massive vacuum leak. And the car was trying to figure out what was going on. Since the mass air flow wasn't seeing everything the car was confused. When you seal that valve, or get a new one, I would say the revving will stop. Unless you're doing it on purpose.
Old 06-27-2013, 05:04 PM   #13
DangerZL1
Drives: 2023 Black ZL1 Auto
I'd see if the ground off end would fit inside a piece of PVC or other tubing. If so, I'd silicone or RTV it inside the tubing and cap it off. It has to be repairable vs spending the $98 on a new one.
Old 06-27-2013, 05:10 PM   #14
Zl1vite
Exactly what I was thinking. Put a can around the canister. Like a silicon tube or rubber hose.
