Old 01-23-2017, 06:30 PM   #15
Steve2150
Drives: 2016 Camaro 2SS, Red Hot
The Corvette one plugs into 12v outlet, can that be used on Camaro
Steve2150 is offline   Reply With Quote
Old 01-24-2017, 08:12 AM   #16
CAM-FIFTY
CAM-FIFTY's Avatar
Drives: 2016 Red Hot 2SS
You can easily snake it in from passenger side of the hood like this:
2017 Black Z06 2LZ M7
2016 Red Hot 2SS A8 - Sold
My Camaro journey here and here.
CAM-FIFTY is offline   Reply With Quote
Old 01-24-2017, 08:16 AM   #17
Nino8309
Drives: 2018 Summit white 2SS 1LE
Hook up under hood. You bypass the RVC system by hooking directly to the battery. The amperage sensor on the battery cable needs to see the load so the vehicle knows the state of charge.
Nino8309 is offline   Reply With Quote
Old 01-24-2017, 08:31 AM   #18
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
So are you guys who are using it under the hood using the positive (under the red cap) and the negative, or some certain point elsewhere for a ground instead?
Old 01-24-2017, 08:37 AM   #19
CAM-FIFTY
CAM-FIFTY's Avatar
That's how I did it, that's how it is listed in the user manual that came with the tender.
Old 01-24-2017, 09:16 AM   #20
toro1966
toro1966's Avatar
Drives: 2017 Camaro SS Convertible 50th
+1 Exactly.
toro1966 is offline   Reply With Quote
Old 01-24-2017, 11:57 AM   #21
Memphis SS
Memphis SS's Avatar
Drives: 2017 SS A8 Hyper Blue/White Stripes
Yes Sir... I've got mine connected under the hood. easy to access. I'm using a Battery Butler brand. Works Well. I did order the GM unit with the car but it is much larger unit to have to hide under the cover, the Battery Butler is much smaller and easier to place.
2017 Camaro 2SS Hyper Blue
2011 Camaro 2SS 2004 Corvette CE SOLD
Memphis SS is offline   Reply With Quote
Old 01-24-2017, 01:10 PM   #22
SS 1LE
マスタング = 遅い
SS 1LE's Avatar
I've been using this on my past cars. The Battery Tender Junior. All the "brains" are on the wall unit, so nothing to have sitting on or near the car.
Old 01-27-2017, 07:46 AM   #23
Memphis SS
Memphis SS's Avatar
Nice...
That's how the one from Battery Butler (Lectric Limited Inc.) is built, They list it as a Battery Storage / Maintenance Charger
I've used their product for about 15 years.
Old 01-27-2017, 09:05 AM   #24
cooden
cooden's Avatar
Drives: '16 Camaro 2SS & '15 Durango R/T
Mine is hooked to the terminals under the hood, I didn't completely close the hood, but it is latched and ran the wires down the front and then put the car cover on. There is more than enough slack so that nothing is pulling on them. I am using the LPO battery tender.
'16 2SS: Summit White/Adrenaline Red/A8/Whipple Supercharger/ARH Longtube Headers/Corsa Xtreme Exhaust/Roto-Fab Cold Air Intake/Eibach Pro Kit/M228 Wheels/Lots of GM Accessories
cooden is offline   Reply With Quote
Old 01-27-2017, 09:12 AM   #25
Mighunter
Drives: 2017 Summit White 2SS
Originally Posted by Drags1998 View Post
Mine is hooked up to the Terminals under the hood. Wires running through the grill, I would not put the charger in the Trunk! Running the wires into the trunk is OK, I just don't trust ANY charger INSIDE the car anywhere.
yeah, for me the wires go into the trunk but the unit is not in the trunk
Mighunter is offline   Reply With Quote
Old 05-05-2017, 08:08 PM   #26
foundcamarolifeisgood
Drives: 2011 2SS
would like to see underhood pics of connections
foundcamarolifeisgood is offline   Reply With Quote
Old 05-06-2017, 06:51 AM   #27
Grandpawmoses
Grandpawmoses's Avatar
Drives: 2017 2SS 50th Anniversary
Doesn't matter. The Tender will be disconnected when operating the car.
Grandpawmoses is offline   Reply With Quote
Old 05-06-2017, 08:23 AM   #28
camaromike77
camaromike77's Avatar
Drives: S O L D
That's the one I use as well. Connected it under the hood, and fished the wires through the hood vent, so I was able to close the hood fully.
Club F1FTY
