03-11-2021, 01:50 PM | #43 | |
Drives: 2018 NFG 2SS 1LE! Join Date: Jul 2018
03-11-2021, 01:51 PM | #44 | |
03-11-2021, 01:56 PM | #45 |
Drives: 2019 ZLE Join Date: Jul 2020
Fresh fluid is rated at the dry boiling point. Over time, and depending on exposure, the fluid absorbs water and the boiling point drops dramatically to it's wet boiling point. It doesn't take long to contaminate fluid. For example:
Fluid Dry Boiling Wet Boiling Motul 660 617 400 Motul 600 594 401 Brembo HTC 64T 635 397 SRF 608 518 The primary reason people have good luck with SRF is because it is less hygroscopic than conventional brake fluids - it absorbs less water over a given time. Conventional fluid can absorb moisture sitting on a shelf. The more important number is wet boiling if you don't plan to change often. If max dry boiling is important, be prepared to change the fluid regularly. The negative with SRF is that some of the moisture it is exposed to is not absorbed by the fluid and can remain suspended in the brake system and can become corrosive. You need to change SRF every year. Conventional fluid is designed to resist corrosion and can sit in the system for much longer periods. but it will be reduced to it's wet boiling point Like everything related to tracking a car, there are trade-offs. I like Brembo HTC 64T for its low compressibility and high dry boiling point. Gives you a firmer pedal. But I will be changing it a lot more frequently due to it's relatively low wet boiling point. Link to a comparison of all the major brands: https://thebuildjournal.com/tech-gui...view-analysis/ Last edited by Pcormier66; 03-11-2021 at 02:00 PM. Reason: Fix link |
03-11-2021, 03:28 PM | #46 |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
I run my Motive dry. Just pay attention to the MC, that's all. Before removing the MC connection, bleed off the pressure at the Motive, otherwise you'll get brake fluid wanting to spray everywhere. Take your time and pay attention to the details.
Set aside plenty of time to work on your brakes. And don't look to bleed/flush the evening before a track day unless you are prepared to deal with unforeseen problems. Like a broken bleeder. Get spares. Spare bleeders, banjo bolts, copper washers. Do not rush working on cars. Especially working on cars that will be run to their limits. I do a full flush at the beginning of the season, then an easy "burp" before an event. A burp being just a short bleed to push a bit of fluid thru the caliper. Obviously, the highest stressed fluid is going to be in the caliper, so pushing out the caliper fluid is a good thing. I maybe get about a 1/3 to a 1/2 cup out total with each burp of all four calipers. I used to use SRF, now I use HTC 64T, better pedal feel and no hot compressibility that SRF can bring. I focus more burp on the fronts as the rears don't see the same stress. But if you are using your stability/traction control on track then the rears will see more stress than not using it. As for the ABS cycling, once you engage the ABS while driving you'll be mixing/moving that captured fluid. Eventually after a few bleeds/ABS use it's pretty much a non issue. The ABS unit is not seeing the heat stress like the calipers do. I can see wanting to remove that small amount of captured fluid after a DOT3 to DOT4 change over or due to a contaminated fluid issue though. After doing bleeds enough you'll get a feel for how much fluid you can bleed out that equals the caliper volume. I store my fluid in multiple heavy duty zip lock bags with desiccant pellets and a hygrometer in my humidity controlled basement family room. Since I do the burps, I only use as much fluid as needed. Yes, I open a container and keep using it throughout the season. But since I keep it in a low humidity environment, I'm confident in its integrity.
03-11-2021, 03:33 PM | #47 | |
Lol, I used to use the ATE Super Blue and the regular ATE amber back in '08 in my '95 Z28. I knew when I had pushed enough fresh fluid. I drove my old Z in WV back in 2019 and it still had the Super Blue from when I sold it in '09 and the pedal felt amazing!
03-11-2021, 09:03 PM | #48 |
SRF all the way. I only change once a year because I want to enjoy the car not speed bleed between sessions. I would take note of anything that requires or potentially requires work while at the track. We pay a lot of $$$ to track anything that can potentially cause an issue over a weekend or god forbid ruin the weekend just isn’t worth it.
03-11-2021, 09:56 PM | #49 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
Swapped to stainless brake lines today...thought I would take a quick clip of using the MityVac to bleed the brakes.
https://youtu.be/L4KQIJ1yWXA
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
03-11-2021, 10:24 PM | #50 | |
Drives: 2020 Zl1 A10 Riverside Blue Join Date: Mar 2020
03-11-2021, 10:40 PM | #51 | |
I guess I just have gotten used to it. The moment you see ANY fluid in the tube, you are pulling it from the caliper. I'm not sure if you saw the reservoir in the video, but that was the amount I pulled doing the whole vehicle. It's a great multi-purpose tool. I also did my oil and diff today and used the MityVac for both. The Motive is a great product and it's pretty easy to bring track-side if you are going to be running HPDE. I also had better luck with my Motive dry.
2017 HBM SS 1LE
03-27-2024, 09:38 AM | #52 |
BLEW BIU
Drives: 2018 2SS 1LE Hyper Blue Join Date: Oct 2017
For those tracking their car and using Brembo HTC64, how often are you bleeding it? I recently switched from Endless to Brembo, so I wasn't sure if Brembo needed to be bled every couple of track days, or if it was good for several days. Thanks in advance!
03-27-2024, 11:08 AM | #53 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
No experience with Brembo, but just fyi SRF didnt require any bleeding for a season, while Willwood EXP (which I liked a lot performance amd price wise), required a bleed every 5 days or so. Hopefully somebody will chime in with your fluid experience, but you may try bleeding at say 4 days and see what results you get. If it comes out pretty clean, it was too soon Cheers!
03-27-2024, 12:54 PM | #54 | |
BLEW BIU
