TireRack
Old 10-10-2019, 06:26 PM   #1
tt11camaro
Drives: 2011 chevrolet camaro 2ss
turbo manifold?
hey guys im wanting to build a single turbo kit for my camaro but i cannot seem to find a single turbo manifold that will fit it. any help would be great
i already have a borgwarner s475 t6 that id like to use on it as i only plan to make 650 to 700 wheel.
also doing a zl1 rear end and if you dont mind even though its the wrong section, i know i need center section and axles but do you need knuckle aswell?
tt11camaro is offline   Reply With Quote
Old 10-10-2019, 10:00 PM   #2
graf101
Trouble_SM
graf101's Avatar
Drives: 17' Summit White ZL1
A zl1 manifold works well
graf101 is offline   Reply With Quote
Old 10-11-2019, 02:48 AM   #3
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
Ebay forward facing headers work well.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 10-16-2019, 12:26 PM   #4
Turbo_2010_SS
Drives: Single Turbo 2010 Camaro SS
factory ZL1 exhaust manifolds work very well, have used them for both single and twin turbo configurations.
Turbo_2010_SS is offline   Reply With Quote
Old 10-16-2019, 12:33 PM   #5
608RS
608RS's Avatar
Drives: 2015 2ss
i don't know if this will help, but Huron Speed is doing a group-buy for their single turbo kits. this might work for you since the cost doesn't include a turbo but you get pretty much everything else outside of a few odd-end items.
https://www.camaro5.com/forums/showthread.php?t=562058
2015 Camaro 2ss, NicKey Performance built/tuned
608RS is offline   Reply With Quote
Old 10-16-2019, 01:15 PM   #6
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
His turbo is a T6 and I believe Huron's single kit for the camaro is only a T4.
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 10-16-2019, 01:19 PM   #7
608RS
608RS's Avatar
Drives: 2015 2ss
ahh i missed that, thanks for pointing that out. that won't work then :(
Old 10-17-2019, 07:49 AM   #8
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
That’s a physically big turbo... not necessary for the power level you are shooting for. Stick to a 7675 T4 and you have some turbo kit options (Turbonetics or Huron Speed) as well as the 7675 is easier to package in the engine bay. If you are dead set on using the Borg, you’ll have to fab up everything (not a big deal if you have the skills/tools).
RealQuick is offline   Reply With Quote
Old 10-31-2019, 11:11 AM   #9
2011WhiteSS
2011WhiteSS's Avatar
Drives: 2011 White 2SS
He could swap to a 1.25 A/R T4 housing and have it cut for whatever Exhaust wheel he has 92 or the 96 if it would fit on the Huron Kit in the position they have the turbo in the engine bay.
2011WhiteSS is offline   Reply With Quote
