Vararam
Old 09-17-2019, 05:00 PM   #1
patroklai
Enthusiast
Drives: Camaro SS | e92 M3
Overdrive Alternator Pulley
Hey guys,
Does anyone know where I can pick up an overdrive pulley for my alternator? I currently run an SLP Performance 25% Underdrive Pulley/Harmonic Balancer that was installed back in 2014. It's mostly fine but I need to pick up some extra charging on the low end/idle.
I've been doing some research online and it seems these things are gems to find. Any insight on where to look is greatly appreciated.
patroklai is offline   Reply With Quote
Old 09-17-2019, 05:55 PM   #2
GONIF
GONIF's Avatar
Drives: 73 VETTE ,, 05 2500hd diesel,14 1LE
Call SLP and tell them your problem and they will tell you the pully needed.
OLD GUY FLYING FAST AND LOW
GONIF is offline   Reply With Quote
Old 09-17-2019, 11:52 PM   #3
Bo White
Bo White's Avatar
Drives: 2015 Summit White 2SS 1LE
Probably wont help none. These cars dont charge all the time anyway.
Bo White is offline   Reply With Quote
Old 09-18-2019, 05:12 PM   #4
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
I have one I have never used, and I don't use it because My idle is 950 because I am built. I got it just in case for some day from a rebuilder I know...… its just not needed.....And frankly heard things about the SLP underdrives...and not that they are harmonic balancer but more like stock and prone to stock problems... as in way old posts of them falling apart like stock.... I never figured squat for producing any power gain from my balancer it was for balance from a radical cam. My good starter took care of header heat stroke problem.
christianchevell is offline   Reply With Quote
Old 09-18-2019, 08:44 PM   #5
patroklai
Enthusiast
The pulley is fine. No problems with it. But my battery voltage drops at idle. I just have no idea where to pick up one that could over drive the alternator only. I'll try calling slp.
Old 09-21-2019, 09:09 AM   #6
christianchevell
Like I said the over drive for the alternator would simply be a different sized pulley for the alternator most likely available from a local rebuilder of alternators which would just turn the alternator a little faster with a smaller pulley...…. But you may need more than that sounds like your in need of a battery more to me..... and yes it does drop at idle the output of the system...…. turning lights on should increase the output BTW....
Old 09-21-2019, 01:01 PM   #7
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
12.3v - 12.5v is normal when the battery gets fully charged. The ECU control's the actual output of the alternator.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 09-21-2019, 03:23 PM   #8
Bo White
Bo White's Avatar
Correct
Old 10-01-2019, 09:40 AM   #9
patroklai
Enthusiast
Question - I'm looking at a high output alternator and the seller (apex) is telling me it comes with a overdriven (standard type) pulley. Our cars use the decoupler type (the ones that spin freely when the engine decelerates), but this one is not.
Would that be a problem? Does anyone know?
Old 10-01-2019, 09:41 AM   #10
patroklai
Enthusiast
This makes me curious. If the ECU controls this, then what is the point of a high output alternator?
Old 10-02-2019, 06:48 PM   #11
christianchevell
The point would be to blast max power when using a stereo and the pull is there making it put out more...….
Old 10-07-2019, 06:19 PM   #12
patroklai
Enthusiast
Has anyone installed an alternator with a pulley that is not the decoupler type? Looking at one option from apex. Its over driven and not the decoupler type. My other alternative is powerbastards, a nut less power but uses stock decoupler pulley. Price is the same on both
Old 10-07-2019, 07:28 PM   #13
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Do you actually have a problem with killing the battery, or do you just have concerns because the voltage is lower than you expect. Like these guys said, the ECU controls the alternator, and it definitely does not run all the time. I have had a 25% underdrive for the past two years, and I have no problems with it. I idle the car in the staging lanes at the track, fans running on high, starting it, shutting it off, basically doing all sorts of battery killing stuff - the original battery from 2011 still is going strong. Just wondering if you've actual got an issue, or just looking ahead to what you think might become a future issue.
GPI Max Package 2.0: Brodix BR7 heads/GPI porting, MAX3 cam, ST2116LSR, BSR Max Lift rockers, LS7 LSXR with 103mm TB, Vararam OTR, Mcleod RXT, G-Force/Strange 9" IRS setup with 4.63 gear. 551whp, 11.1@124mph.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 10-08-2019, 09:22 PM   #14
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Well, since nobody has actually answered your question......
No, it will not harm anything by switching to a standard pulley. Millions of cars run them EVERY day.
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
