Vararam
Old 06-28-2019, 10:11 PM   #1
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
High intake temps..
So I've upgraded from 60mm turbos to 76mm turbos. Car keeps having high intake temps even on low boost( 11psi) intake temps are around 125* at the end of the pass.
Car is on E85 and spraying twin #5 nozzle meth with 100% methanol. Now that's just gate. I see well over 170* on 16psi.
The intercooler just can handle the bigger turbos.
I'm thinking of ditching the intercooler completely and running a small dry shot (25 or 50) of nitrous before the IAT and throttle body to control temps.
Should I keep the intercooler or no? Dont seem like it does much anyway.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 07-05-2019, 06:43 PM   #2
Scuzz
Scuzz's Avatar
Drives: 2012 Camaro SS
You are seeing high intake temps even with meth? On 24lbs without meth I was 220 iat end pull. When we added meth temps dropped the longer the pull went. I saw one pull go from iat 110 start to 72 end of pull on 24lbs.
We saw that the race intercooler had trouble keeping up once we went over 18lbs.
2012 Camaro SS Automatic
AGP Twin Turbo LSX427 / ADM Magic / 4L80
“1360 Rwhp 1225 Rwtq 25 lbs of boost”
Scuzz is offline   Reply With Quote
Old 07-05-2019, 08:31 PM   #3
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
Maybe try using a water and meth mix , I've read that when water turns to steam the molecules expand over a 1000 times and dissipate the heat tremendously. The meth only there to increase the fuel and knock suppression, it's the water that takes the temps down
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 07-06-2019, 11:35 AM   #4
hillshooter
Drives: 2015 Camaro SS commemorative
I see between 100 and 115 degrees of intake temps with intercooler only, I dtiched meth last year. this is on 20 pounds of boost with 68MM turbos. I would look elsewhere. those big turbos should be super efficient on low boost and not make that much heat. what are the specs of your intercooler?
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
hillshooter is offline   Reply With Quote
Old 07-07-2019, 02:27 PM   #5
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Send a message via AIM to SSE 4 2SS Send a message via Yahoo to SSE 4 2SS
Good lord....
I run 110-120 IAT's at the end of a pass, a MILE pass with intercooler only at 27 lbs of boost.... 76/75's. We have a home made (shop) intercooler that is 26 inches wide, 14 inches high, and 4 inches thick.... We back cut the steel bumper to increase airflow across the intercooler. We also baffled the inside of the intercooler to direct airflow to ensure even coverage of boost flow across the cooler face...
With the original turbos, 67/66's, and the "kit" provided intercooler, we ran 190's at the end of a 1/4 mile pass.... on spring pressure of 11 lbs...
If the car feels like it is on rails, you are probably driving too slow. -Ross Bentley
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
“If everything seems under control, you're just not going fast enough.” Mario Andretti
If you can turn, you ain't going fast enough...
SSE 4 2SS is offline   Reply With Quote
