03-18-2014, 07:27 PM | #1 |
2013 Camaro SS1LECTSVZ28
Drives: 2013 AGM 1SS/1LE Join Date: Nov 2012
CTS-V 6 Piston Brake kit from $1185.00 (updated)
7/09/2015
I just check prices on the front rotors and they have gone up t0 $255 / $258 Be aware my pricing in this thread is from 2013.....subject to change! 5/08/2015: If you need dust seals for the CTS-V/ZL1 calipers or pistons/seals here are the parts numbers: 19207044 Dust Seals: Appear to be dealer only, about $25/caliper 25940445 Pistons & Seals (dust seals not included) $116.96/caliper 4/4/2013 I updated the title price from the $1050 to $1200 because the ACDelco pads ($45) are not the same material as the OEM Brembo/Ferodo 1000 pads. ($175) PIF = Pay it forward....I will use this to mark threads for information I have located or found that I could not find easily here and may save other the time and some money. Time to pay it forward! I finally ordered my set-up today so it was time to share. From my research into 6 piston set-ups for my car I found by far the lowest prices on Amazon if you are willing to use Silver or Yellow (or powder coat). The qty in stock fluctuates and sometimes the items go on back order, but if you keep checking back they are usually restocked often. You can get a 6-piston front big brake set-up for about $1050.00 to $1300.00 depending on rotors and lines you pick. Here you go: Part numbers and prices as of 3/18/2014 Silver CTS-V Front 6 piston Caliper ACDelco 172-2488 $246.46 Silver CTS-V Front 6 piston Caliper ACDelco 172-2487 $250.62 Yellow CTS-V Front 6 piston Caliper ACDelco 172-2521 $240.11 Yellow CTS-V Front 6 piston Caliper ACDelco 172-2522 $265.79 Front pads (See Notes Below) I removed the less expensive front AC Delco Pads as the material is not the OEM Brembo/Ferodo 1000 material. For track use please purchase the OEM pads p/n 171-1040..About $175 See page 3 Front Pin Kit ACDelco 18K2108X $20.98 Front 2-Piece Rotor ZL1/CTS-V ACDelco 177-1145 $222.56 Front 2-Piece Rotor ZL1/CTS-V ACDelco 177-1146 $246.87 Front Dual Cast Rotor CTS-V ACDelco 177-1105 $165.57 For the CTS-V upgrade on an SS you will need:
UDATE: 4/4/2014 I ordered the OEM pads and received them today.......The pictures do not do them justice as far as how different the material is betweern the OEM pads and the AC Delco pads I have received data in regards to the factory pads temp ranges from testing at GM and will share what I can later.... Finally, I am using the Silver CTS-V rear calipers to match the front and they ARE NOT a direct bolt on. Both the GEN1 and GEN2 calipers require modifications to use. I KNOW "but everyone says they bolt on" They are all wrong as a modification is need to both to use. I ordered both sets-to view/confirm the differences....I will post a separate thread about the calipers, differences and mods that need to be made to use them. -Matt Do you really need CTS-V big brakes! http://www.camaro5.com/forums/showthread.php?t=360552. Last edited by Dropspeed; 07-09-2015 at 03:40 PM. |
03-18-2014, 07:55 PM | #2 |
No Tags/Habitual Violator
Drives: 2012 SIM 2SS/RS & z71 Join Date: Sep 2011
Great info Matt !
I havent used my brakes enough yet to justify this upgrade, but have the feeling it's likely to be my first mod. Are the caliper numbers left and right? |
03-18-2014, 08:02 PM | #3 |
BL1ZZRD
Drives: '16 Camaro 2SS, '20 Equinox Redline Join Date: Jul 2009
Thanks for posting! Those are good prices! I'll be doing this next year and I'll probably get the silvers and send them to Mike the powdercoater for $180 to match the RJT of the car!
03-18-2014, 08:17 PM | #4 |
Drives: rumble bee,2SS 6sp Join Date: May 2009
same part number for the first 2 piece rotor and the cast rotor just a heads up
blk 2ss 6spd with sunroof.
intake,tsp cam,full exhaust,pcmforless tune,trailing arms,toe rods. hopeing for 11.9 because my g/f said she will take the cam and the suspension back if not. |
03-18-2014, 08:19 PM | #5 | |
2 piece rotors are directional and left/right as well because of the cooling veins...1 Piece Dual cast are not directional Matt
03-18-2014, 08:20 PM | #6 | |
Good catch....Corrected above!
03-18-2014, 08:33 PM | #7 |
Drives: 2011 2SS/RS M6 VR Join Date: Aug 2011
Awesome post. Not ready to pull the trigger yet, but this is subscribed. Thanks
03-18-2014, 09:11 PM | #8 |
Drives: '14 1LE Join Date: Nov 2013
Great information - this will let me buy a piece or two at a time
03-18-2014, 09:23 PM | #9 |
So Cal Race Team
Drives: 2013 Camaro Join Date: Mar 2010
This brake set up makes a huge difference in stopping power....
Damn, I just got ZL1 rotors that cost a lot more than those....oh well, next time...
03-18-2014, 11:00 PM | #10 |
So Cal Race Team
Nope, it's my opinion based on my experience...I'm not consumer reports...
03-18-2014, 11:15 PM | #11 |
So Cal Race Team
Experience is a better thing, armchair heckler, not so much....
03-18-2014, 11:20 PM | #12 |
Great post! Subscribing for future info.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
2010 Camaro 2SS/RS | RotoFab CAI | ARH 1 7/8" LT Headers w/ HFC | SW Retro Exhaust | ZL1 Shifter | Ridetech Coilovers | FE4 conversion | UMI toe rods & trailing arms | Prothane Subframe & UCA bushings | Detroit Speed sways | Forgestar F14 wheels | ZR1 Blue Calipers | Tuned by ADM Performance SSeric's Build Thread |
03-18-2014, 11:21 PM | #13 |
ROAD COURSE JUNKIE
Do these bolt right up or is there an adapter needed to make them work?
03-18-2014, 11:22 PM | #14 |
So Cal Race Team
They will bolt right up...you need a little longer brake line than the stock SS
