Vararam
Old 04-06-2015, 12:23 PM   #1
CobraR
Drives: 2010 2SS
102mm Throttle body on TVS2300
Ok, lets beat this to death one more time
I am tempting to max out my tvs2300 setup, one of the last things left is open it up to a 102mm and throttle body.
I found an older post by Ray@RDS saying they were doing some testing and thought they might be onto the cause of the throttle plate closing/limp mode.
Anyone have anything on this? I hate to spend the 800 dollars on the machine work and throttle body to just have issues. However it looks like this could gain about 20-40 rwhp from what I have read in most cases.
CobraR is offline   Reply With Quote
Old 04-06-2015, 03:38 PM   #2
LuckyZL-1
Ragtop Rocket!!!
LuckyZL-1's Avatar
Drives: Black on Black Convertible
Contact JessRayo on here I believe he finally worked out his problem.
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package.
744rwhp 727rwtq
LuckyZL-1 is offline   Reply With Quote
Old 04-06-2015, 05:11 PM   #3
Trackman
Trackman's Avatar
Drives: 67RS Camaro ,Black 2013 ZL1
If Ray at RDS can offer a guarantee that his "calibration" works go for it.
Larger throttle bodies in high HP applications have proven to make decent gains.
There is no proven cure for the reduced engine power issue that I know of yet.
Trackman is offline   Reply With Quote
Old 04-06-2015, 06:02 PM   #4
CobraR
Drives: 2010 2SS
That's what I was figuring, then the guy that tunes the car said just leave the stock one on it for now.
Old 04-06-2015, 07:13 PM   #5
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
Been running a 102 for years no issues. The problem was with NW TB's. MY TPIS solved this in 09....
Well maybe not 09 but you get the point, lol
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 04-06-2015, 07:45 PM   #6
H-E
Drives: 2010 zr1 Camaro 2011 vert
We used one of our tricks to help jess and may be offering this to others
H-E is offline   Reply With Quote
Old 04-06-2015, 08:25 PM   #7
CobraR
Drives: 2010 2SS
I didn't see the tpis even being offered right now.
H-E I will give you a call tomorrow.
Old 04-06-2015, 09:28 PM   #8
Trackman
Trackman's Avatar
I know of a throttle body that had the air foil design and it failed.
Old 04-06-2015, 09:34 PM   #9
Trackman
Trackman's Avatar
When I was at the Texas mile last year it was still a common problem on big HP cars. I think there are a few rare units out there that seem to have a little extra tq needed to stay open. I don't know for a fact but I think speed density tunes have better luck at staying open as well.
Old 04-07-2015, 09:09 AM   #10
swiftkart
swiftkart's Avatar
Drives: 2010 SS/RS LS3 M6
2 years and no problems with my NW102 at over 800rwhp.
swiftkart is offline   Reply With Quote
Old 01-17-2018, 03:14 PM   #11
hou30guy
Drives: 2011 convertible 2ss/rs
Regular nw 102mm or the boosted version
Sent from my SM-N950U using Tapatalk
hou30guy is offline   Reply With Quote
Old 01-18-2018, 05:41 AM   #12
Bildo
Bildo's Avatar
Drives: 2012 2SS/RS LS3
NW told me directly only positive displacement super chargers create the problem with his setups.
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
Bildo is offline   Reply With Quote
Old 01-18-2018, 06:53 AM   #13
hou30guy
I have a nw and it wont stay open past 4600rpm and 14psi
Old 01-18-2018, 08:13 AM   #14
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
Running NW 102 with proper adapter 16 lbs.. no issue.
Pro-tuned is offline   Reply With Quote
