Vararam
Old 05-05-2016, 09:36 AM   #211
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
If you didn't measure such a small difference (1/4"), would you really notice it? When you're driving around, your own weight and that of any passengers will change things a bit from there. I'm a little concerned that perfectly levelling the car out will end up making it look like a mild "tail-dragger".
Firmer springs don't have to ride harshly as long as they're not so low that you're getting into the bump stops a lot more frequently. Beyond that, harshness is more commonly associated with design choices in shock/strut damping curves.
Norm
Old 05-05-2016, 10:07 AM   #212
Mrbowtie26
Mrbowtie26's Avatar
Drives: 2015 CRT 1SS 1LE
Norm
I do notice the visual difference yes though it's slight. I have a pretty good eye for noticing things that only bother me lol.... i was thinking of ordering front springs with a 1"drop and rears with a 1.25" drop but I am unsure of which brand to go with that has those numbers.
Mrbowtie26 is offline   Reply With Quote
Old 05-05-2016, 10:34 AM   #213
Firefighter
Firefighter's Avatar
Drives: Black '13 2SS/RS/1LE w/NPP/NAV
I can't remember why but iirc I was once told that a slight rake is desirable for performance with the 1LE package.
Firefighter is offline   Reply With Quote
Old 05-05-2016, 11:24 AM   #214
Norm Peterson
High speed aero is likely better and turn-in possibly a little crisper.
Norm
Old 05-05-2016, 01:40 PM   #215
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
Originally Posted by Mrbowtie26 View Post
With a 2015 1LE camaro my rear at stock ride height is about 1/4" higher than the front. I would like to lower the front 1" and the rear 1.25 while still retaining the cornering characteristics of the car. If it rides a little harsher Im fine with that I just do not want increased body roll. Any suggestions on doing this without going to coilovers ? Thanks
We offer the front and rear BMR lowering springs separately so that you can custom tailor the stance you want. Due to the nature of what they are, lowering springs have a higher spring rate than the stock springs. This mean two things:
1) They will be more firm than stock. That does not mean harsh though.
2) They will reduce body roll.
Apex Motorsports is offline   Reply With Quote
Old 05-12-2016, 06:03 AM   #216
kcox2010
synergy2011
kcox2010's Avatar
Drives: 2011 synergy green 1ss/rs
Send a message via AIM to kcox2010
Will pfadt 1.25 lower spring with 2754020 offset 40 have any issue with the strut plate hitting or rubbing I just install them and it very very close but can't tell if it rub or hitting thanks
2011 synergy green ss/rs,rally stripes
kcox2010 is offline   Reply With Quote
Old 05-12-2016, 05:49 PM   #217
Apex Motorsports
What wheels you are running is something that has to be taken into consideration.
Old 05-12-2016, 07:33 PM   #218
kcox2010
synergy2011
kcox2010's Avatar
20x 9 45th anniversary replica wheel 40 offset seems like a 1/8 inch of clearance hard to tell
Old 03-05-2017, 10:24 PM   #219
SS Wacko
Drives: 2013 2SS
I just found this thread. Great info..
SS Wacko is offline   Reply With Quote
Old 04-23-2017, 08:21 PM   #220
MagooJr
Drives: 2010 2SS ABM, 68 SS/RS 396 4sp
Great post, thanks for making it easy for all of us. Now I know what suits my needs, this forum ROCKS!
MagooJr is offline   Reply With Quote
apex lowering springs, apex motorsports, best lowering springs, camaro lowering springs
