06-30-2022, 12:41 AM | #1 |
Drives: 2010 Camaro 2SS Join Date: Jun 2022
New to tuning
I have never tuned a car before and so I have some questions about tuning my 2010 Camaro 2SS 6A
1.) What happens if I unplug the tune, will my car revert to factory settings? 2.) Which tune would you guys recommend? 3.) What should I expect when getting a tune? Mods: BBK Long Tube Headers, k&n CAI, Hollowed out cats w muffler and resonator delete. Thanks. |
06-30-2022, 05:58 AM | #2 |
What are you trying to do? use a handheld?
06-30-2022, 11:40 AM | #3 | |
Started#gottalovethatblue
2) It’s best to go to a reputable shop and get a tune from them. However, there are many places that do mail order tunes. DynoSteve is a forum favorite here. I personally like Fasterproms. 3) Not sure if you’re driving a manual or an automatic, but an automatic will see a much more dramatic difference in the tune than a manual purely because of the transmission aspect of the tune. Either way, you should expect to see more power, throttle response, and if an automatic, MUCH improved shifting. I hope this helps!
06-30-2022, 04:03 PM | #4 |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
1.) What happens if I unplug the tune, will my car revert to factory settings? {keeping the factory tune is part of the procedure. You can go back to it any time. Keep in mind that it’s not ‘invisible’ as some might say. If someone (dealer, etc.) really wanted to look, they can see it had been flashed.}
2.) Which tune would you guys recommend? {Really depends on what you’re looking to do. I can tell you some of the more aggressive tunes “can” lead to trans issues. If you’re stock, I’d recommend a more middle of the road tune i.e. not so aggressive.} 3.) What should I expect when getting a tune? {A little better performance, nothing too glaring but definitely firmer shifts. And something I just recently learned is, it seems like the Nannie’s (stabilitrak, traction control) have been ‘turned off’ or altered, but I was told in NO uncertain terms that nothing was changed on those two features. But your tale may vary!} Those are my experiences.
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
07-01-2022, 12:33 AM | #5 |
07-01-2022, 12:35 AM | #6 | |
Saw your build journal for yours, gave me a ton of ideas. Thanks a lot. Last edited by kevsbumblebee; 07-01-2022 at 01:11 AM. |
07-01-2022, 07:22 AM | #7 |
And why would you need to change the tune back?
07-01-2022, 07:55 AM | #8 |
Drives: 13 CAMARO 2SS LS3-04 SILVERADO LS3 Join Date: Dec 2021
07-01-2022, 09:02 AM | #9 |
Here in the Unicornish Republik , we like to flash back to stock before a semi-annual smog check. Just in case the tune altered the air-fuel mix enough to bring Gollum and other Lords of the CARB Realm down on us. One tuner said it’s not necessary and one said it might be. I kind of doubt that’s the reason in SD though.
07-01-2022, 10:03 AM | #10 | |
07-01-2022, 10:23 AM | #11 |
Yeah, long tubes and no cats…that’s the stuff of fantasy and legend here. Ironically, where real ‘hot rodding’ probably started. But I have to give a shout out to the Moonshiners too!
07-01-2022, 03:46 PM | #12 |
07-01-2022, 08:40 PM | #13 |
07-02-2022, 06:59 AM | #14 | |
Thanks for looking through my build thread. She's definitely been a labor of love and I'm nearly where I'd call her as close to perfect as I'll get her, but it's been 9 years in the making. Best of luck and happy modding!
Tags |
tune |
