05-26-2015, 08:30 PM | #1 |
Drives: 2011 Victory Red 2SS M6 Join Date: Dec 2013
Oil change after winter storage?
Hi all,
I just went through my first winter with my Camaro and had a quick question. I changed my oil before putting it in storage for the winter. Is there any reason to change it again, 5 months later, having not driven it at all in between? Thanks! |
05-26-2015, 08:52 PM | #2 |
Drives: 2018 Hyper Blue 1SS 1LE Join Date: Jul 2011
I change mine once a year usually may/June and have had the oil analyzed the last 2 yrs. Oil has held up fine they even suggested going to longer intervals (oil is cheap so I will change as I see fit)
Ryan
Ryan
* 2018 1SS 1LE Camaro Hyper Blue Metallic Car Build: http://www.camaro6.com/forums/showth...0#post10049680 |
05-27-2015, 04:53 AM | #3 | |
Drives: 2014 2SS/RS Camaro Join Date: Dec 2014
Nope. You'll be fine.
2014 2SS/RS, L99, SW LTH w/HF Cats, GMPP Ex. Z/28 CAI, FR41s in PVD Black Chrome, Recaros, Pfadt Sway
377hp, 383tq 12.739@110.44 MPH |
05-27-2015, 05:31 AM | #4 |
376 cubic inches of fun
No. And you did the right thing to change the oil before, not after storage.
05-27-2015, 11:06 AM | #5 |
I do the same thing. I change the oil in November and don't drive it till about April.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs |
05-27-2015, 05:31 PM | #6 |
Thanks for the feedback everyone, I appreciate it!
05-27-2015, 07:33 PM | #7 |
Chevrolet Performance
Drives: Camaro Chroma Join Date: Jul 2010
It depends. So far those posting have changed before storage, but here's an alternative view... Depending on the environment, a car sitting all winter is going to get some condensation, which contaminates the oil. Can it get burned off in the spring once you get the engine to operating temperature and drive it? Possibly. But why take that chance when the cost of fresh oil and a new filter is so low? I drive less than 1,000 miles per year, so I change the oil each spring before taking my car out of storage and it's good until next spring.
To each his own! |
05-27-2015, 07:39 PM | #8 | |
Drives: 2011 IOM 2SS/RS M6 Convertible Join Date: Feb 2014
Thats true, and thats the reason many choose to change the oil both before and after storage.... but if you're only doing it one or the other, it really ought to be before IMO. I'd say oil gets more contaminates from driving than it does sitting in the oilpan over the winter.
05-27-2015, 07:45 PM | #9 | |
05-27-2015, 07:51 PM | #10 | |
yeah at 1000 miles, the oil is basically new either way. We put about 4500 on ours last year and changed it just before putting it away for the winter. I thought about changing it again this spring but decided not to. Modern synthetic oil is light years ahead of the ol 3 months or 3000 mile days.
05-27-2015, 08:38 PM | #11 | |
I did not and have the oil analysis to back up that it's fine with it sitting during the winter. Ryan
Ryan
05-27-2015, 09:53 PM | #12 |
Don't see a need to change synthetic because of winter storage. Shouldn't lose any properties just sitting there all winter.
Change mine once a year, usually before racing it. Would change more if I was putting more than 3,000 a year on it.
MYBADSS
05-28-2015, 05:51 AM | #13 |
Drives: 2013 1LS, 2013 Ram 1500 Join Date: Mar 2013
i usually do mine 2x a year. spring and fall. spring is usually within a month of me pulling it out, fall is because i reached my "due" mark. i average 7500-9000 miles during the summer on mine.
05-28-2015, 06:59 PM | #14 |
if your going to change the oil befor and after why put new oil in it. its just going to sit in the aluminum oil pan all winter. might as well just drain it and not put new in until spring. Put a big sign on your steering wheel NO OIL
