Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 09-09-2012, 07:54 PM   #1
jimmy5
jimmy5's Avatar
Drives: 2012 ZL1 #450
How To Install Catch Can on a ZL1
People have been wanting a detailed write up on this. Before you go jumping me, Tracy and I resolved our differences so I went with an RX catch can. I bought it from Jannetty Racing.
First remove your engine cover
Then you can locate the tubing you need to remove
To remove the tubing, get a flathead screwdriver and use it to unclasp the connector
Then connect the vacuum hose to the ports
To mount the can, you have to attach it to the radiator shroud, and you will need a longer bolt than the one in the current housing, to get this you take it from the upper radiator mount here, I bent the bracket that came with the kit myself to help move it out of the way.
Then place it between the shroud and the radiator, this makes a small gap, but I don't think it will affect cooling at all
Here it is in place, the larger base diameter valve is the outlet, the one in the middle is the inlet
Then I looked as I shut the hood to make sure I had clearance, I had tons
After that start the engine, check for CEL, check all connections for a vacuum leak, and you are done, for those of you wondering about the mounting area being stiff enough, it is, and the rubber bumpers of the shroud and upper radiator mount look like they will absorb much of the vibration
jimmy5 is offline   Reply With Quote
Old 09-09-2012, 08:25 PM   #2
BoostedX2
BoostedX2's Avatar
Drives: VR ZL1 #259/Nissan 370Z NISMO
Why would you get a CEL?
Thanks!
BoostedX2 is offline   Reply With Quote
Old 09-09-2012, 08:33 PM   #3
jimmy5
jimmy5's Avatar
Kinked hose, leaking connection, hole in hose you don't see. Basically an increase or decrease in crank case pressure if something isn't right.
Old 09-09-2012, 09:43 PM   #4
DangerZL1
Drives: 2023 Black ZL1 Auto
Thanks for taking time to write this up. It really looks like an easy worthwhile mod. I need to order one.
Old 09-10-2012, 07:58 AM   #5
sammyv
sammyv's Avatar
Drives: 2013 red Lingenfelter ZL1
Nice job!
sammyv is offline   Reply With Quote
Old 09-10-2012, 08:57 AM   #6
RJ111
RJ111's Avatar
Drives: 2015 ZL1
Mine has 3 valves in the top of the can.Any info on that,since it had no instructions in the box....
Thanks for the write up..
2013 Camaro ZL1,Victory Red # 441....SOLD
2013 Camaro ZL1, Summit White # 3071...SOLD
2015 Camaro ZL1, Summit White # 1325
Rotofab Cai,PCM cc,Kooks Headers,Cats delete,MF X pipe, ZLWin cam,upper/lower, Lingenfelter hx,715 rwhp,646 rwtq, BMR 1.25 Springs, Varro VD01 Wheels,
RJ111 is offline   Reply With Quote
Old 09-10-2012, 09:29 AM   #7
cybercoaster
cybercoaster's Avatar
Drives: 2017 2SS 50th Anv, 1972 RS
thanks !
cybercoaster is offline   Reply With Quote
Old 09-10-2012, 10:33 AM   #8
jimmy5
jimmy5's Avatar
I have only ever seen the 3rd one hook up to an aftermarket intake. I would hook it up like the one listed above and put a vacuum plug on the 3rd port.
Old 09-10-2012, 11:41 AM   #9
Matt @ RX
Guest
Posts: n/a
Jimmy: Great write-up man!
RJ: We are putting the directions on our website actually, just reformatting them for the web. I can send you over the directions via email real quick. I just PM'd you for your email address.
Single or Dual cans can be used on the ZL1's. We have been sending the latest ZL1 cans with the dual valve.
Thanks
Matt
Old 09-10-2012, 11:48 AM   #10
SC2150
Drives: 2012 Camaro RS, RX supercharged
Excellent Jimmy!!!
With the dual valve, connect the secondary valve line to the air bridge or coupler so when at WOT any excess crankcase pressure is evacuated using the suction upstream of the tb.
If using the single valve like Jimmy shows your fine as is.
The ZL1 has a pretty effective oil trap on the cleanside (congrats GM!) so we only need to deal with the dirty side on these engines and the dual valve uses the inlet side as additional suction/evac as needed and the checkvalve prevents any mixing with the cleanside.
SC2150 is offline   Reply With Quote
Old 09-14-2012, 07:04 AM   #11
alyssasdad
Go VOLS!!!!!
alyssasdad's Avatar
Drives: ZL1 #1344 VR, M6
This might be a stupid question but...... If you take the longer bolt from the upper radiator mount,what do you replace it with?
1.GOD
2.Family
3.Camaro........& the TENNESSEE VOLS!!!
alyssasdad is offline   Reply With Quote
Old 09-14-2012, 08:21 AM   #12
closs2sx
closs2sx's Avatar
Drives: 1970 chevelle
Jimmy how much oil have you trapped over xxx miles and anyone with the three port can can you tell me how much oil you trapped over xxx miles and state which can you have three port or two. I have the two port and have not gotten any oil in 800 miles wondering of that's normal?
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car
2015 Z06 Z07
Daytona Sunrise Orange Metallic
Dads Car
2013 ZL1 vin 963
Crystal Red Tint Coat/Black Wheels
Exposed Carbon Fiber Insert
6 Spd Manual
closs2sx is offline   Reply With Quote
Old 09-14-2012, 12:53 PM   #13
jimmy5
jimmy5's Avatar
With the bolt that you take from the housing.
Old 09-14-2012, 12:53 PM   #14
jimmy5
jimmy5's Avatar
I dont know yet, I only have 600 miles on my car.
